Uxcore.dll named curse!!
R
Rooster
Gentlemen.. I have tried EVERY single thing to solve that uxcore.dll error in
Windows Live Messenger.
-I unistalled and installed WLM. Result: The Same!
-I even formatted my hdd many times and installed XP and tried again
installing WLM. Result: Same again!!
-I've tried deleting that contacts folder from where it was as many people
over net said. Result: SAME AGAIN!!
And I tried many recommendations that I've read in many forums,blogs etc.
but none of them helped anyway.
Doesn't Microsoft think of solving that aching problem??
J
Jonathan Kay [MVP]
Greetings Rooster,
Although it's UXCore that's crashing, it's typically third-party software which is
interfering with Messenger and causing the crash.
Since you've been reinstalling, it's most likely a piece of software you would normally
regularly install (perhaps even some sort of security/antivirus/et al). We'd have to go
one-on-one with some crash dumps to hopefully determine the culprit if you can't really think
of anything which would be causing it however.
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2010 Jonathan Kay - If redistributing, you must include this signature or citation
4 days to go!
"Rooster" <[email protected]> wrote in message
news:[email protected]
