V652 CyberPhone K
U
ukguy
Windows upgrage advisor stated this device should work. Vista installs the
driver, but comes back with message the driver did not install correctly. I
tried to update driver, but vista states this driver is uptodate. anybody
have any suggestions?
many thanks
Chris
B
B Hope
Hi Chris
I use a Cyberphone with voipvoice software for Skype and it refused to work
in Vista. I found a suggestion in another forum (I think it was on Skype)
that a temporary workaround is to install the XP version of usbaudio.sys
from the C:\windows\system32\drivers and copy it to the same location in
Vista. That worked for me though the phone's keypad and Skype integration
didn't work at least I could make calls by dialling out from the keyboard.
Hope that helps
Barry
"ukguy" <[email protected]> wrote in message
news:[email protected]
> I
> many thanks
> Chris
U
ukguy
Hi Barry
thanks for this very usefull. unfortuately i made a clean install of
vista and no longer have xp on my machine. where can i find the XP driver.
also i am running 64 bit version of vista.
thanks chris
> many thanks
> Chris
B
B Hope
I would be happy to email you with it. Send a message to my address with
this subject - remembering to delete REMOVE in my address. Whether it will
work with 64 bit I would not know but nothing is lost if you back up the
original.
Regards
> Hi Barry
> driver.
> thanks chris
>> the
>> I
>> anybody
>> many thanks
>> Chris
U
ukguy
Hi Barry
thanks for this, i cant fiqure out your e-mail so this is mine. i be
happy if u send it thanks
[email protected]
"ukguy" wrote:
> Hi Barry
> thanks chris
> > many thanks
> > Chris
B
B Hope
Hi Chris
I've sent the file and a link to a forum on the Skype site that should help.
Regards
Barry
> Hi Barry
> [email protected]
> "ukguy" wrote:
>> Hi Barry
>> driver.
>> thanks chris
>> > the
>> > correctly. I
>> > anybody
>> > many thanks
>> > Chris
