vbs for Task Manger check which process using A lot of CPU resource
M
moonhkt
HI All
I have below vbs, to report win32 process, But I does not know how to
select a process using A lot of CPU resource , said over 70% ?
Ouptut as below
c:\temp>
c:\temp>chkprocess.vbs
ID Caption Pool Usage
0 System Idle Process 0
4 SYSTEM 0
676 smss.exe 13400
732 csrss.exe 161548
764 winlogon.exe 75620
808 services.exe 91280
820 lsass.exe 63596
1020 ati2evxx.exe 26984
1036 svchost.exe 47296
1108 svchost.exe 52320
1220 svchost.exe 448212
Option Explicit
Dim pad(4)
dim strComputer
dim objWMIService
dim ele
dim colProcess
function fmt (str,lenstr)
if lenstr - len(str) > 0 then
fmt = str + string(lenstr - len(str), " " )
else
fmt = str
end if
end function
strComputer = "."
pad(1)= 6
pad(2) = 30
pad(3) = 10
Set objWMIService = GetObject("winmgmts:" & _
"{impersonationLevel=Impersonate}!\\" & strComputer &
"\root\cimv2")
Set colProcess = objWMIService.ExecQuery("SELECT * FROM Win32_Process
Wscript.Echo fmt("ID",pad(1)), fmt("Caption",pad(2)), fmt("Pool
Usage",pad(3))
Wscript.Echo string(pad(1), "=") ,
string(pad(2),"="),string(pad(3),"=")
For Each ele in colProcess
if ele.caption <> "r2win.exe" then
Wscript.Echo fmt(cstr(ele.ProcessId),pad(1)), _
fmt(ele.Caption,pad(2)), _
fmt(cstr(ele.QuotaPeakPagedPoolUsage),pad(3))
end if
Next
set ObjWMIService = nothing
set colProcess = nothing
