Video (DivX/xVid AVI) Meta Tags
Dzomlija
Resistance is Futile
Does anyone know of a way to embed meta tags into DivX AVI files?
I use Window Live Photo Gallery (that oddly enough also shows videos) to tag all my images and videos with keywords such as show title, actors, etc...
But if I clear the Gallery database and re-initialize it (or copy a new AVI file from backup disk onto the hard disk), then the Videos show up as untagged.
Is there is way to embed the metadata into the AVI files so that the information is preserved, even if the file is later moved to another computer, similar in fashion to the XMP, IPTC or EXIF tags of JPEG files?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
J
John Inzer
> actors, etc...
> files?
If you right click one of your DivX AVI files
and choose...Properties / Summary tab /
Simple or Advanced button...you will notice
you cannot enter information the way you
can on a JPEG (for example).
IOW...there is no way for Windows to 'write
back' to the .avi file. Your tags will be archived
in the Pictures.pd4 file so if you delete or
rename the .pd4 file...your tags are gone.
John Inzer MS-MVP
Digital Media Experience
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
Dzomlija
> actors, etc...
> files?
John Inzer MS-MVP
Notice
I am a volunteer
Thanks for the reply, John.
This I knew, but I guess I was hoping that somebody had a way of doing it.
I guess I'll have to wait for Windows 7 with it's built-in support for DivX, so maybe it'll also then support XMP metatags for AVI files...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
J
John Inzer
> it.
You're welcome.
John Inzer MS-MVP
Notice
I am a volunteer
