VirtualPc to VirtualBox
B
Bill Grant
<[email protected]> wrote in message
news:[email protected]
> Is there a way to change a machine virtualPc to a machine VirtualBox ?
> Bye
> Thanks
> Massimo
If you remove the VirtualBox guest additions you should be able to simply
create a new vm using the .vhd file. If you want to convert the disk format
from .vhd to .vdi there is a utility called clonevdi. There is a sticky
topic at the top of the VirtualBox on Windows Hosts forum with details.
