Vista 64 Audio Problem?
23
I can't seem to get any sound out of my microphone or any other input device(such as a guitar interface) and the problem persists even with a USB headset. I've checked all the settings, nothing is muted and Vista says everything is working fine. I can even see the green bars light up when I play something or say something into the mic. The Microphone only lights up the first 2 bars though, but the volume is maxed and again, nothing is muted.
I've googled to see if I could find other people with similar problems and It seems to be a common issue with no solution(so far?) as there are many open forum topics.
Additional Information:
I'm using onboard audio with an Asus P6t Deluxe V2 and I have updated drivers which I have reinstalled as well.
lemur
1,533
Location
University of Kentucky
Check your input volume controls
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
1,337
You stick the microphone in the right port?
    Sony Vaio Z46GDU
    P9700@2.8GHz w/6MB L2 cache 1066MHz FSB
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
lemur
1,533
Location
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
23
#8
Thanks Lemur, I followed the guide, but I still didn't get anywhere. It seems to not be able to hear me. It looks as though all input devices that involve putting a sound into my computer do not work with Vista. I just double checked my motherboard to see if something was wrong in there, but I'm finding no issue with the wiring.
lemur
1,533
Location
#9
Can you verify mic is good?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
lemur
1,533
Location
#11
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
8
#12
Seems like Lemur covered the basics.. Have you installed the appropriate drivers for your sound card? You can download them from the manufacturers website. Or use the CD that came with it. If its onboard then you can go to the manufacturer of your mother board's website. It's possible Vista didn't come prepackaged with the drivers you need and you'll only get basic functionality, in your case just about NO functionality.
1,337
#17
You need the right driver. What does device manager say? Under sound controllers.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
lemur
1,533
Location
#19
Try using SIW to identify hardware
SIW | Download
** EDIT ** Specifically sound
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
1,337
#20
Get Realtek drivers. Belarc Advisor is clearer. Drivers:
Realtek
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
