Vista C: Drive & Data E: Drive
P
I find that I am frequently running low on space on my VISTA C: drive. I
have used the disk clean up and still could do with more space.
However, my E: drive is virtually empty. Can I start saving files to this
even though it is marked as DATE E: drive.
If I can, is it possible to transfer / cut & paste / copy & delete files
from my Vista C: drive to the DATA E: drive?
Many thanks for any advice you can give me.
Paul
R
Rick Rogers
Hi Paul,
Provided it is not your system manufacturer's recovery volume, then yes.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Paul" <Paul@xxxxxx> wrote in message
news:7EF01FFE-9E13-4C1D-9CD8-70C282F1CB92@xxxxxx
> Paul
P
Thanks for your reply Rick. However, without wishing to sound dumb, how do I
find out if the E: Drive (which is headed DATA) is my system manufacturer's
recovery volume?
Paul
"Rick Rogers" wrote:
> Hi Paul,
> Best of Luck,
> > Paul
click your Start orb, then "Computer" how big is drive E: ? if it's
anywhere form 4-10 Gig then its probably a recovery disk. If its larger
then it probably is another hard drive or partition that can be used. Yes
you can cut, paste, copy, even install programs to it.
news:708C02BB-AA91-46DE-BE8B-A04A3A532656@xxxxxx
> I
> manufacturer's
> recovery volume?
> Paul
>> Hi Paul,
>> Best of Luck,
>> >I
>> > this
>> > files
>> > Paul
