"brbgtgp" wrote:
> Changing a User's Default Printer in the Registry
> See Article ID: 156212
> HKCU \Software \Microsoft \Windows NT \CurrentVersion \Windows
> Device Reg_SZ Data (here you make the device changes.)
> Note: You will see the Devices folder under the CurrentVersion with the list
> of printer devices installed, their spooler and connection type.
> "Geekeezer" wrote:
> > I am having the "Can't set a default printer problem" as well. It comes
> > into play with me, not on a network, but all the time. The major issue,
> > as I saw posted somewhere else here, is with programs like Adobe Reader
> > (Acrobat) that only print to a default printer. In other words I can't
> > print PDFs. That is a real PITA as I
> > am a REALTOR and PDFs are my WORLD. I did see an answer by "Alan" that
> > mentioned some "HKEY-BLAH BLAH BLAH," But there was no info about what
> > to do with it. I am not a registry savvy guy. Its a new machine and the
> > manufacturer was no help either! This has been going on for several
> > months. Should I just go buy an Apple?
> > Geekeezer
So I encountered same thing today, unable to print acrobat reader.
There are a few things you should look for... This applies from win2K until
vista
HKCU\Software\Microsoft \Windows NT \Current Version \Windows
If you do not have the Windows key, borrow from a friend.
Right-click then Export the key...
Go to original workstation then double-click on printer.reg this will apply
the tree into the hive.
or Copy below into a notepad.exe and rename printer.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows]
"DebugOptions"="2048"
"Documents"=""
"DosPrint"="no"
"Load"=""
"NetMessage"="no"
"NullPort"="None"
"Programs"="com exe bat pif cmd"
"device"="Any printer name1,winspool,Ne01:"
OK. So let's move on to changing values. Let's look into Devices or
PrinterPorts
Verify your device listed.
example
Any printer name4 REG_SZ winspool, Ne03;
Any printer name3 REG_SZ winspool, Ne02;
Any printer name2 REG_SZ winspool, Ne01;
Any printer name1 REG_SZ winspool, Ne00;
In the windows key, right-click "device" then modify...
in Value data field, enter below
Where it says "any printer name1" look into your system devices and pick one
that applies to you. (please do not stick your head inside the computer.)
ALT+F4 to close
