Vista DNS Problem
M
Michael Lock
I have a new installation of Vista Ultiamte 32-bit, and I am completely
unable to access the internet.
I am using an HPnx9420 and have up to three NICs available to me:
* on-board cable (Broadcom NexXtreme Gigabit)
* on-board wireless (Intel Pro/100 3945 abg)
* PCMCIA wireless card (LinkSys WPC300Nv2)
All have the same problem:
* the network connection comes up as "Local Access Only"
* I can see other devices on the local network
* I can not see the internet (big red "X" on the worldwide conenction)
* Internet explorer can't display any pages whatsoever
Strangely, while I can ping any IP address in the world (local subnet and
external), I can't ping anything by the equivalent host name or URL.
Other bits that I have tried:
* Netbios over DHCP is ENABLED
* IPv6is is DISABLED
* IPv4 Offload checksums are DISABLED
* All forms of anti-vrius, anti-spy (including Windows Defender) and
firewall (including Windows Firewall) are either DISABLED or REMOVED.
Please help. I really need to get back to work.
MDL
P
Pradeep GanapathyRaj [MSFT]
I have EXACTLY the same problem Michael. I have COMPAQ NC 8430 LAPTOP and a
COMPUSA FMI ROUTER (3 yr old). See my problem statement below. I tried
several things - what partially worked is this:
Solution1:
1) Go to your router setting. Or connect an XP machine to the router.
2) Do ipconfig /all on the XP machine. Get the DNS server name
3) Go to the LAN CONNECTION. Go to properties on the IPV4 connection. Click
ADVANCED tab. Enter the DNS server name manually
After this, I was able to access internet. But my trouble is - I switch
between multiple networks !! So, everytime I come home, now I have to enter
the DNS again !!
Solution2:
Restart the router !! Strangely this worked every time. But it is a PAIN !!
I am still searching for the answer. If you get it, let me know !!
Background:
I have a Vista laptop and a CompUSA router (at my house). I was having a XP
tablet PC which worked like a charm - I open it, plug in the Ethernet wire
and it gets connected, no problem. But with Vista, it doesn't work like
that. I have to POWER RESET my router everytime to get my internet
connectivity working. Without the power reset, my vista computer can see my
other computer on the network, but the DNS configuration somehow doesn't
seem to work
My computer details:
Machine - Companq NC 8430 (2 GB memory)
Network adapter - Broadcom NetXTreme
Router - CompUSA router
<See image attached>
What I tried:
I thought I may need to update the driver, so went to the Broadcom site and
downloaded the latest driver.
http://www.broadcom.com/docs/driver_download/570x/win_vista_32-10.8.0.0a.zip.
After this, the functionality seems to work OK. But Vista started
bluescreening every 4-5 hrs or whenever I went to standby and back (not sure
exactly what's the cause). So, I have now reverted back the driver install.
Any ideas/tips would help.
Thanx and regards
"Michael Lock" <Michael Lock@discussions.microsoft.com> wrote in message
news:26F5CE65-9318-4950-B872-409B35473567@microsoft.com...
> MDL
R
Robert L \(MS-MVP\)
Pradeep, Have you tried to disable IPv6?
Michael, please post the results of ipconfig /all and nslookup.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Pradeep GanapathyRaj [MSFT]" <pgan@microsoft.com> wrote in message
news:A8C43ADC-8111-48D1-BF8E-51C4F0497A81@microsoft.com...
>a COMPUSA FMI ROUTER (3 yr old). See my problem statement below. I tried
> Solution1:
> Click ADVANCED tab. Enter the DNS server name manually
> enter the DNS again !!
> Solution2:
> Background:
> XP
> my
> seem to work
> What I tried:
> and
> sure
> install.
> Thanx and regards
>> MDL
A
Arjumand Bonhomme
I'm running Vista Home Premium and I've had the exact same problem as the
previous two posters, and discovered the same solution as poster#2 (Pradeep's
1st solution, manually entering the DNS server).
I have disabled IPv6 without any luck (meaning I have unchecked the IPv6
protocol for both the LAN and wireless adapters). I don't think it is the
"broadcast flag" issue (http://support.microsoft.com/kb/928233) because the
IP address and gateway are properly received via DHCP. Also, I have a Win2K
and Linux box also receiving their DNS info via DHCP without any issues.
Below is result (without a manually entered IP for DNS server) of both the
nslookup command and the ipconfig /all command:
I change networks quite a bit (this is a laptop) so having to muddle with
the DNS server every time is very annoying. Any help/insight into why this
is occuring would be greatly appreciated.
#####BEGIN COPY-PASTE#####
C:\Windows\system32>nslookup
*** Default servers are not available
Default Server: UnKnown
Address: 127.0.0.1:53
> quit
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : codepad
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.md.comcast.net.
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : hsd1.md.comcast.net.
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network
Connection
Physical Address. . . . . . . . . : 00-19-D2-78-87-5C
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connection
Physical Address. . . . . . . . . : 00-16-36-FD-36-EC
IPv4 Address. . . . . . . . . . . : 192.168.0.188(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, May 29, 2007 8:58:24 PM
Lease Expires . . . . . . . . . . : Wednesday, May 30, 2007 10:08:03 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
Primary WINS Server . . . . . . . : 192.168.100.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 9:
isatap.{49D620FB-62FB-4DEC-A630-979749AF7C99}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 16:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.0.188%34(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 17:
Tunnel adapter Local Area Connection* 18:
Tunnel adapter Local Area Connection* 19:
Tunnel adapter Local Area Connection* 20:
Tunnel adapter Local Area Connection* 21:
Tunnel adapter Local Area Connection* 22:
#####END COPY-PASTE#####
> > Solution1:
> > Solution2:
> > Background:
> > XP
> > my
> > seem to work
> > What I tried:
> > and
> > sure
> > install.
> > Thanx and regards
> >> MDL
D
DaveW
Hey guys, I've been studying this problem a bit at where I work. Here's
a setting I've changed that seems to make a difference.
Go into "Network Sharing Center"
Click on "Manage network connections"
Select "Properties" for the interface you're using.
Select the IPv4 selection and click properties
Click the "Advanced" button at the bottom of the window
Then click on the WINS tab and at the NetBios settings at the bottom
select either "Enable NetBios over TCP/IP" or "Disable NetBios over
TCP/IP". I've only tried this on the former.
Then hit ok and see if that makes a difference.
What I'm seeing on my traces is after the client learns the DNS entry
and sends out a DHCPINFORM packet which the DHCP server responds to
again. It's confusing our DHCP server a little. I don't know if this is
the same problem you all are experiencing or not, but I figured I'd
share it. Please let me know if this makes a difference.
Thanks,
DaveW
DaveW
DaveW's Profile: http://forums.techarena.in/member.php?userid=26262
View this thread: http://forums.techarena.in/showthread.php?t=736778
A
Arjumand Bonhomme
Thanks for the suggestion, but no luck here. Same result, no dns servers
acquired from DHCP.
> Thanks,
> DaveW
> DaveW
A
augustus_meyer
I am wondering, where the WINS-Server adrs came from in
the output of ipconfig/all.
Adrs is different from DNS-Server adrs.
Is there really a WINS server available ?
If not, it might (but should not) block the use of the DNS-Server adrs.
You can always configure the network card using static IPs, and static DNS
servers.
Better than rebooting the router, at least.
