Vista Event Viewer
V
vegaspat
When opening the Event Viewer I discovered there were NO logs. Instead I
received a message that MMC could not create the snap-in. The snap-in might
not have been installed correctly.
This is a 7 month old eMachine and I have no idea how to install the
snap-in. I can't even find out where to check to see if it's enabled or
disabled per the Help File.
What can I do to get my Event Viewer to work properly.
Thanks.
P
P. Di Stolfo
Hello,
maybe you'll want to try this:
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=970546&SiteID=17
It describes a very similar problem.
Here's another information and a possible fix for the problem:
http://msmvps.com/blogs/bradley/archive/2007/06/13/repairing-vista.aspx
I hope this will help you.
Greetings,
P. Di Stolfo
http://blog.lysorp.com - Small Windows blog in German language
"vegaspat" <vegaspat@xxxxxx> schrieb im Newsbeitrag
news:4804DB91-B09C-4CF0-BACE-30CB23CEE02E@xxxxxx
> might
> Thanks.
V
vegaspat
Thanks for the response. I have already been to the TechNet board and was
going back there to try and post a message. One of the posts in that thread
had the very same error message that I did. The bad thing is that I can NOT
rename the MMC.exe file. Vista just won't let me.
Isn't it strange that this seems to be a Microsoft issue and yet there is no
documentation or fix on their web site?
It seems that several people have had this problem and were able to overcome
it and I can't even rename a silly file? My Task Scheduler has the same
error message. I didn't even know that until I read someone's post and
checked mine out.
I will check out the other link you sent.
Thanks again and if you have any other ideas I would appreciate hearing
about them.
> Thanks.
