Vista extremely slow to copy files to network drive
N
Nick Gilbert
My new Vista machine seems to take AGES to copy files to network drives.
For example, copying a single 10mb file has so far taken about 10
minutes and it hasn't even actually started the copy yet - it still says
"Calculating..."
Windows XP can copy the file in about 4 seconds. Why should Vista take
several thousand times longer to do the exact same thing? I'm using the
same logon credentials on each machine.
How can I fix this?
Thanks,
Nick...
R
R. McCarty
This is a known issue with Vista, there is a hotfix available but the
circumstances for the hotfix may not exactly match your particular
problem.
See the following:
http://support.microsoft.com/kb/931770/en-us
"Nick Gilbert" <nickg@newsgroup.nospam> wrote in message
news:uc5NtUE0HHA.3400@TK2MSFTNGP03.phx.gbl...
> Hi,
> For example, copying a single 10mb file has so far taken about 10 minutes
> "Calculating..."
> How can I fix this?
> Thanks,
> Nick...
N
Nick Gilbert
This KB article seems to be more relevant to my problem:
http://support.microsoft.com/kb/932170
....but doesn't include a hotfix - just workarounds. I'll have to give
them a go.
Nick...
> problem.
> See the following:
>> Hi,
>> "Calculating..."
>> How can I fix this?
>> Thanks,
>> Nick...
R
R. McCarty
Good Luck, it's sort of a random type issue. Some Vista PCs exhibit
the slow copy and others do not. I haven't found a "Common Set" of
conditions where the copy issue happens.
news:%23QLvQiE0HHA.2312@TK2MSFTNGP05.phx.gbl...
> ...but doesn't include a hotfix - just workarounds. I'll have to give them
> a go.
> Nick...
>> problem.
>> See the following:
>>> Hi,
>>> "Calculating..."
>>> How can I fix this?
>>> Thanks,
>>> Nick...
N
Nick Gilbert
Unfortunately none of the workarounds seem to have any effect. It still
takes several minutes to copy a tiny file to a network drive.
It looks like copying files in Vista is totally broken!
I really really hate Vista. It's just so incredibly buggy!
Nick...
>> a go.
>> Nick...
>>> problem.
>>> See the following:
>>>> Hi,
>>>> "Calculating..."
>>>> How can I fix this?
>>>> Thanks,
>>>> Nick...
D
dean-dean
You might try disabling Remote Differential Compression.
You can disable it by going to Control Panel\Programs and Features > Turn
Windows Features On or Off.
> Hi,
> "Calculating..."
> How can I fix this?
> Thanks,
> Nick...
H
HeyBub
> still takes several minutes to copy a tiny file to a network drive.
> Nick...
There are lots of ways to copy a file: Drag-and-drop, clipboard, COPY,
XCOPY, etc. Then there's the copy TO vs copy FROM. You might try various
permutations to find one that works better.
T
theclyde
#8
On Jul 27, 9:47 am, "dean-dean" <dean-d...@discussions.microsoft.com>
Disabling Remote Differential Compression definately improved my copy
& move speeds
P
PaulB
#9
I'm using Avast antivirus and any time I copy to another computer, Avast
generates an error that it could not scan. This causes a huge delay
especially if you are copying a large number of files. If I want to copy , I
temperarily disable the
Standard shield. This may not be your problem of course but I know a number
of people us Avast.
Paul
> & move speeds
