Vista Home Premium Boot-up options
D
Dhana
Hello,
I installed a clean install of Vista Premium from Windows XP. Now everytime
i boot up my computer i have to pick an option whether to boot up from Visa,
Last know best version or Windows XP. How do i aviod seeing those options
ande bootup by default from Vista?.
D
Dhana wrote:
> Hello,
> and bootup by default from Vista?.
Vista has a command-line tool called 'bcdedit' which is such a pain to
use that these folks wrote a graphical front-end for it:
http://www.vistabootpro.org/
I'd say you shouldn't remove that boot menu until you've used Vista for
a week or so. You can also set the default timeout for 5 seconds so you
don't need to interact with the menu if you don't want to.
D
Dhana
How do i set up the time out limit?
"Don" wrote:
> Dhana wrote:
> > Hello,
D
Control Panel::System and Maintenance::System
[You may need to enter the Administrator's password here.]
Then click on 'Advanced system settings'. The timeout is
set in the 'Startup and Recovery' settings dialog.
