Vista Home: Where is Local Users?
G
Guest
Specifically ... need to find the Computer Management > Local users and
Groups in order to do some management.
I'm able to find it in Vista Business, but not in Vista Home.
TIA
Russel
Brink
Staff member
mvp
TIA
Russel
Hi Russel,
Sorry, the "Local Group Policy Editor" is not available for the Vista Home Basic or Home Premium versions.
If you tell us what you are wanting to do, then someone or myself may know a way to do it in the registry instead.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
K
Kerry Brown
That mmc console is not available in Home versions of Windows. You can
manage local user and groups via a command prompt with the NET command. Type
NET /? for help. It's a pain but it has been that way since XP came out with
Home and Pro versions.
Kerry Brown
Microsoft MVP - Shell/User
http://www.vistahelp.ca
<nobodygr8@xxxxxx> wrote in message
news:e8Aq4XmLIHA.4476@xxxxxx
> TIA
> Russel
H
Hank Arnold (MVP)
> Type NET /? for help. It's a pain but it has been that way since XP came
> out with Home and Pro versions.
Why not use Control Panel/User Accounts?
Regards,
Hank Arnold
Microsoft MVP
Windows Server - Directory Services
K
Kerry Brown
You can't set up groups in the Control Panel applet. With the NET command
you can create security groups then add/remove users to the groups. I don't
know if this would do any good with Home versions as they use simple file
sharing but it is possible. I don't have any Home versions to test but I'm
wondering if it's possible to add domain users via this method?
Kerry Brown
> Regards,
> Hank Arnold
> Microsoft MVP
