Ok guys, here's what's up. I am using my laptop to connect to a wireless router that is connected to the internet. What I am trying to accomplish is to have my Xbox360 to connect through the internet through my laptop using ICS, but the xbox can't connect to the internet. The laptop is on Vista Home Premium 32bit. Windows Firewall has been turned off completely while testing, the comp. does have nortons so I disabled it from turning on at startup and it is not running. I have read these forums and it seems no one has an exact answer to this problem, but I'm going to try and see if mine is different.
There are a few places I think the hold up could be at...
1: At the manage network connections page it shows the wireless NIc connected to internet, should I be clicking its properties and then going to sharing and enabling it? (i have it enabled on the connection the 360 is plugged to, the wired LAN) because there is no sharing tab under the wireless NIC that acually has the internet connection. I enabled sharing on the LAN NIC that is free(the one the xbox360 is connected to).
2: It is showing my LAN(xbox360 connection) as " 'unidentified network', shared ". All connections are set to private network. under status it shows sent packets, but no received packets. i click diagnose and repair and try to make it autoassign new IP, and even reset network adapter, doesn't help. I have updated both NIC's driver's, they are current.
here is my ipconfig /all as well.... ALL help is GREATLY appreciated!!
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\chris>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : chris-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 802.11b/g WLAN
Physical Address. . . . . . . . . : 00-1A-73-6C-06-33
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2c4b:3ec7:9f09:f582%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.104(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, February 12, 2008 12:02:31 AM
Lease Expires . . . . . . . . . . : Wednesday, February 13, 2008 12:18:00 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 184556147
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0E-10-99-85-00-1B-24-58-AD-11
DNS Servers . . . . . . . . . . . : fe80::2c4b:3ec7:9f09:f582%10
74.128.1.31
74.128.1.33
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1B-24-90-1A-30
Link-local IPv6 Address . . . . . : fe80::fdeb:3957:45b4:4584%8(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.69.132(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 201333540
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{3D4A77DA-8B67-4E76-977D-2AB334106
875}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.104%16(Preferred)
74.128.1.31
74.128.1.33
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{770BD83B-E6B2-4185-AC61-DA89A8D16
983}
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.69.132%17(Preferred)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : 6TO4 Adapter
C:\Users\chris>
74.128.1.31
74.128.1.33
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
875}
74.128.1.31
74.128.1.33
983}
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
C:\Users\chris>
