Vista - ICS error msg
D
drewby doo
hey guys, hoping somebody has an idea for this one. i've seen this issue
described pretty much exactly in one other post, but nobody replied to the
guy.
i have a computer running vista ultimate, connected to LAN/WAN via a
wireless connection to a router. the router and wireless adpater are setup to
establish an IP using DHCP. i also have an xbox 360 connected to the vista
machine via a crossover cable to the onboard network adapter. the 360 and
machine can communicate fine. i'm trying to enable ICS so the 360 can use the
internet connection, but i get skunked when go into the wireless properties
and tick the checkbox to "allow other users to connect" and click OK - the
error msg is "An error occurred while internet connection sharing was being
enabled." below that is "(null)", likely where an error code should be.
i had this working a few weeks ago and just recently tried jumping online
via my 360, but despite my best efforts it's a no-go. does anybody know the
services required to make ICS work in vista? i did change 2 services
recently, altho they were almost certainly not related to any network
functions windows uses. any help would be appreciated, thanks!
D
Damo
Hi Drewby Doo,
I have the same problem. Did you manage to resolve it at all?
Any information would be very helpful :)
Cheers
D.
> guy.
R
Rodrigo Pires
Hi guys, I'm also having the exactly same problem. Did you resolve that??
Please let me know.
Thanks.
"Damo" wrote:
> Hi Drewby Doo,
> Cheers
> D.
> > guy.
A
admin
http://windowshelp.microsoft.com/Windows/en-US/Help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
"Rodrigo Pires" <[email protected]> wrote in message
news:[email protected]
> Please let me know.
> Thanks.
> "Damo" wrote:
>> Hi Drewby Doo,
>> Cheers
>> D.
>> > issue
>> > the
>> > guy.
>> > setup to
>> > vista
>> > and
>> > use the
>> > properties
>> > the
>> > being
>> > online
>> > the
B
Bolt736
> > Please let me know.
> > Thanks.
> > "Damo" wrote:
> >> Hi Drewby Doo,
> >> Cheers
> >> D.
> >> > issue
> >> > the
> >> > guy.
> >> > setup to
> >> > vista
> >> > and
> >> > use the
> >> > properties
> >> > the
> >> > being
> >> > online
> >> > the
Thanks for the instructions on how to click the "Share this connection box"
but on these systems that was already done. it is when the box is checked,
and the network is re-configuring itself, that this null error message occurs.
Bolt
M
Matt
Anyone figure this out yet? I'm having exactly the same trouble trying to
connect my 360 to my pc's internet connection
N
Neel
Same problem here...Hopefully someone has a fix. Think it might have
something to do with a duplicate IP address (though i think all my devices
are set to find IP automatically) is it possible that it has something to do
with a device not on this ICS sharing, but still on the network?
> > > Please let me know.
> > > Thanks.
> > > "Damo" wrote:
> > >> Hi Drewby Doo,
> > >> Cheers
> > >> D.
> > >> > issue
> > >> > the
> > >> > guy.
> > >> > setup to
> > >> > vista
> > >> > and
> > >> > use the
> > >> > properties
> > >> > the
> > >> > being
> > >> > online
> > >> > the
> Bolt
D
Danny F. Barnes
FIXED THIS ISSUE ON MY MACHINE.
Only after -hours- of tinkering.
I was getting the "An erroc occurred when enabling internet connection
sharing. (null)" message also, when attempting to enable ICS on a Sprint
Mobile Broadband connection, to share with the XBOX 360 over ethernet.
I have Windows Live OneCare installed for firewall, virus, spyware
purposes... so, I had Windows Firewall disabled through services, since I am
using OneCare for firewall.
I enabled Windows Firewall, and stopped getting the error message. ICS is
working fine.
Sooo... a step to try, if you have Windows Firewall disabled through
services, enable it.
M
Mario Rozalén
Really fixed!!!
just enable the forewall again and it will work perfectly
thx a lot
> working fine.
rocketero
@ Dany F Barnes
Man, you are a life saver, just right on the money by enabling Windows Firewall through services.msc.
I saw this thread and people at the beginning like 2 and a half years ago.
peace !
