Vista internet drop after some time (need help!)
X
xtremejimmy
My machine keeps dropping the internet after an hour or so of use
online. It normally requires me to restart the laptop to get the
internet to function again. What is strange is that it still sees my
network name but does not allow me to reconnect to it when the internet
drops. I went to device manager and disabled and re-enabled the wireless
and it brought it back to life.
What could be causing this, and is there a fix for it? My dads laptop
with vista doesnt have this problem. I have already tried turning off
the power save feature on the wireless and also unchecked Qos, ipv6, and
both link-layer topology in the wireless network connection properties.
Also, I just did a fresh install of Vista to see if it helps and no
dice. Also updated all the windows updates, even to SP1 and still no
dice.
I have an Alienware aurora m9700 duo core 2.0 ghz, 1 gig ram, 80 gig
HD, Realtek 8185 Extensible 802.11b/g Wireless Device, Vista Home
Premium. Any help from you guys is greatly appreciated!
below is a copy of my ipconfig after the internet drop if this can help
you guys diagnose my problem.
C:\USERS\GIOVI>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Giovi-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Bluetooth Device (Personal Area
Network)
Physical Address. . . . . . . . . : 00-16-41-DE-34-FF
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8055 PCI-E Gigabit
Ether
net Controller
Physical Address. . . . . . . . . : 00-03-25-3D-DA-20
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Realtek 8185 Extensible 802.11b/g
Wireles
s Device
Physical Address. . . . . . . . . : 00-C0-A8-D8-DF-5F
Tunnel adapter Local Area Connection* 6:
isatap.{5A7F6742-859B-43EA-8273-B5E84727F
37B}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
isatap.{43527F9A-174D-409D-97F7-48D5A3FA2
548}
Tunnel adapter Local Area Connection* 10:
isatap.{07F7E442-9979-4E57-9410-174681A18
761}
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
xtremejimmy
Posted via http://www.vistaheads.com
S
Spaceman
hmm?
Maybe a power saver feature on the network card?
check the properties of your network card itself for such.
and BTW:
I don't see any IP addresses in your ipconfig /all .
I am amazed you are connecting to the internet at all
"xtremejimmy" <xtremejimmy.39w2g6@xxxxxx-mx.forums.vistaheads.com> wrote in
message news:xtremejimmy.39w2g6@xxxxxx-mx.forums.vistaheads.com...
> dice.
> Network)
> Ether
> net Controller
> Wireles
> s Device
> 37B}
> 548}
> 761}
> xtremejimmy
P
propman
Maybe his last statement would explain the reason. ;-)
Spaceman wrote:
> and BTW:
>> online.
S
Spaceman
oops, ya.
xtremejimmy,
be sure to enable the network before checking for the power management
tab,
It might not even show up unless the connection is active (on)
"propman" <propman@xxxxxx> wrote in message
news:NnKZj.4594$KB3.3877@xxxxxx
> Spaceman wrote:
> > and BTW:
> >> online.
X
xtremejimmy
I already checked off the power management thing and it still does it.
I can disable and re-enable the realtek in device manager and it brings
it back to life for a little while. Any other takers on what it can be?
xtremejimmy
S
Spaceman
just wondering now,
When your connection is working,
What date does it give for Lease Expires in the ipconfig / all?
"xtremejimmy" <xtremejimmy.39xygf@xxxxxx-mx.forums.vistaheads.com> wrote in
message news:xtremejimmy.39xygf@xxxxxx-mx.forums.vistaheads.com...
> xtremejimmy
S
Spaceman
#8
that should be fine then.
sorry I could not help further.
I will still be thinking about it though.
"xtremejimmy" <xtremejimmy.39y2o8@xxxxxx-mx.forums.vistaheads.com> wrote in
message news:xtremejimmy.39y2o8@xxxxxx-mx.forums.vistaheads.com...
> it shows the expire as of right now for the 25th at 8:36 pm.
> xtremejimmy
