Vista keeps losing my printer drivers!
R
romanom
What brand printer? I have an HP and had a similiar problems, except mine
was more random, sometimes the drivers would reinstall for no apparent reason.
On HP's site they used to have a patch for download about this issue, but it
didn't work, which is probably why the patch is no longer there for download.
There is a fix, sort of:
http://www.microsoft.com/downloads/...5a-eb6b-40e3-ae83-5200b7ef497b&DisplayLang=en
This seems to at least cut down on the number of times this happens to me,
only once has it happened since I installed the update. Before, it would
happen 2-3 times a week.
This fix may also be relevant:
http://www.microsoft.com/downloads/...90-1204-4f94-8ee1-063071797427&DisplayLang=en
"RaisingAlexis" wrote:
> Any time I have to unplug my USB printer, I have to re-install the printer
> drivers. How can I fix this?
T
trickytree7
I have the exact same problem. Every time I plug my HP Printer back in to the
USB port, it reinstalls the driver. So frustrating! I downloaded these
updates, hopefully that helps. Anyway have any other ideas??
I am having the same problem, but when I tried to download the updates
listed, ms.com indicated that my system does not need them? I have an HP
c6180 and two home PCs. I would like to simply plug the printer into
whichever PC I need to print from. However, when I plug the printer back
into the first PC, it finds and reinstalls the drivers, leaving me stuck for
10 minutes until it finishes. Am I doing something wrong? Is there an
obvious better approach? Is there a setting to stop this maddening
autoinstall of drivers that have already been installed?
Thanks,
Jay
T
trickytree7
Jay,
It doesn't appear there is a fix for this. I've even called Dell and they
were completely stumped. This is definitely a Vista bug. I searched MS
website far and wide and found no solutions. SO ANNOYING!! If you come up
with any solution please post it here!
> Thanks,
> Jay
Are there any MVPS or Microsoft personnel who can tell us if there is at
least a formal defect opened by MS or if we are simply out of luck for now?
> Jay,
> > Thanks,
> > Jay
C
cqui3
"Jay" <Jay@xxxxxx> a écrit dans le message de
news:1912369E-000D-4472-A508-8EE83C2C278B@xxxxxx
> now?
>> Jay,
>> they
>> > HP
>> > back
>> > stuck for
>> > Thanks,
>> > Jay
>> > > in to the
>> > > these
>> > > > except mine
>> > > > apparent reason.
>> > > > issue, but it
>> > > > download.
>> > > > to me,
>> > > > would
>> > > > > the printer
It could be that the printer is plugged into a different USB connector. Try
always reconnect in the
same connector.
