vista keeps restarting by itself
B
My Vista computer keeps shutting down and restarting randomly. Seems to
happen every couple hours. This is not a normal restart, as when I see it,
the balck page with white writing comes up and asks me to press enter if I
want windows to start normally.
This event will happen even if I am in the middle of working on the
computer. I am running Vista Business w/ a quad core and intel MB. Any
ideas?
L
Lilykittie22
> ideas?
L
Lilykittie22
Mine keeps doing the exact same thing! i'd love to know how to sort it, its
been a hassle since i've bought my computer a few months ago!
> ideas?
M
Malke
> ideas?
That kind of behavior is usually hardware-related. It could be caused by
overheating, a bad processor, bad motherboard, bad RAM. There really is
no way to tell from your post which it might be. If this is a new
computer, contact the computer mftr.'s tech support for
repair/replacement under your warranty. Otherwise, here are some general
hardware troubleshooting steps:
http://www.elephantboycomputers.com/page2.html#Hardware_Tshoot
Malke
Elephant Boy Computers
"Don't Panic!"
MS-MVP Windows - Shell/User
Dzomlija
Resistance is Futile
2,213
Location
South Africa
My Vista computer keeps shutting down and restarting randomly. Seems to happen every couple hours. This is not a normal restart, as when I see it, the balck page with white writing comes up and asks me to press enter if I want windows to start normally.
This event will happen even if I am in the middle of working on the computer. I am running Vista Business w/ a quad core and intel MB. Any ideas?
The next time it restarts, and you get the menu and the prompt to continue booting normally, see if there is an option that says "Disable Automatic Restart On System Failure", or something similar. If you boot with this option, then the next time Vista "resets", you should see a Blue Screen Of Death (BSOD). The BSOD will provide a particular "STOP" Error code, which will help in identifying the problem.
You can also go into your PC BIOS right after such a reset and then check your system health. Random resets such as the one you descriobe can also be caused by overheating. If this is the case, then you'll need to have a qualified service technician change your cooling system, unless you feel up to the task yourself.
Check that you have the latest drivers installed.
If you are running Anti-Virus software, do a full update and system scan.
If you have over-clocked your system, which a BAD Idea to begin with, then use the default clock/voltage settings for your motherboard and see if that makes a difference.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
