Vista "Local only" connection problem
N
nick.n
I have been running Vista on my laptop with no problems since March
until this morning. Suddenly I was presented with "Unidentified
network" and "Local only". I have tried a myriad of suggestions found
in posts on the net but nothing has helped thus far.
My router is a Netgear DG834G and the laptop running vista has an
Intel PRO/Wireless 3945ABG network adapter.
Any suggestions would be very much appreciated.
Many thanks
Nick
R
Robert L. \(MS-MVP\)
Have you tried Microsoft update? Or these links may help,
Windows Vista Update and downloadPosted: Tue May 29, 2007 6:03 pm Post
subject: Windows Vista Update and download, Reply with quote. Microsoft just
release a new update 941649 on 10/25/07. ...
www.chicagotech.net/netforums/viewtopic.php?t=859
Vista issuesthe Vista laptop has limited connectivity to "Unidentified
network". ... The Vista Unidentified Network or Limited Connectivity could
be hardware, ...
www.chicagotech.net/vista/vistanetissues.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
<nick.n@xxxxxx> wrote in message
news:1194398953.785948.263260@xxxxxx
> Many thanks
> Nick
D
Daniel
Mine is having the same problem as of this morning to and my tech department
at work advised the in windows XP that there is something called winsock that
needs to be cleared out. But so far everyone that i have talked to does not
know how to clear it out in Vista yet i am searching for a way to do it and
if i find out what to do i will post it or if you find out please post it on
here i would appreciate it. I hope this helps you as a start in your search
for answers.
> be hardware, ...
> > Many thanks
> > Nick
N
nick.n
Thanks for your reply Robert L. I had read those posts before posting
on here. I am trying to recall the exact circumstances of the failure
yesterday morning.
When I first powered on my laptop it booted and connected to the
network without any problems. Now, I am not 100% sure, but I think
Norton AV 2007 installed an update and requested a reboot after which
all networking failed. I cannot even connect with a cable to the
router.
When I check the status of the wireless adapter it just has a 169
address and no gateway, dns, etc.
TIA
Nick
R
If you receive 169 IP, that mean the computer can't receive the IP from
DHCP. Try to assign static IP. Or disable IPv6 completely. This how to may
help,
How to disable IPv6 and Tunnel on Vista
http://www.chicagotech.net/netforums/viewtopic.php?t=2102
news:1194426869.052042.278260@xxxxxx
> yesterday morning.
> router.
> TIA
> Nick
P
PTravel
> yesterday morning.
> router.
> TIA
> Nick
First try this: in Device Manager, disable then re-enable your wireless NIC.
Then try this: in Device Manager, uninstall the wireless NIC and then let it
re-install automatically.
After doing the above: Disable IPv6.
Then, do a search on how to edit your registry to set the DHCP Broadcast
flag to 0 for your wireless adapter.
Finally, in Network Settings disable "connect to a more preferred network."
R
realkool2
i know this is old but i tried everything to fix the same for the last two
days and nothing worked until i found this. i uninstalled norton security
center from my acer aspire 5100 laptop. now i am back on the net. during the
uninstall process internet service return. none of the other advice worked
but this. norton has not allow windows updates on my laptop since november
2007. vista has ran smooth since intalling in may 2007 until 2 feb 2008. it
working now. thanks!!!!!
> > yesterday morning.
> > router.
> > TIA
> > Nick
R
#8
Thank you for the feedback.
"realkool2" <realkool2@xxxxxx> wrote in message
news:BBA3459A-5870-40F8-9A48-4AF11AB7D9D4@xxxxxx
> the
> it
>> > yesterday morning.
>> > router.
>> > TIA
>> > Nick
>> NIC.
>> it
>> network."
D
dbcarolina
#9
I have been having a similar problem..but my toshiba satellite with Vista
works with the wireless connections for a local and internet access, but then
if the laptop goes into sleep or hibernate mode if I am not typing on it for
a length of time, then the wireless connection turns into a local only
connection and I have to restart the computer for it to reconnect to local
AND INTERNET (I have tried diagnose & repair, and disconnecting and
reconnecting but that doesn't work). This restarting is such a waste of
time, hopefully you can help me...
thanks
> > the
> > it
> >> > yesterday morning.
> >> > router.
> >> > TIA
> >> > Nick
> >> NIC.
> >> it
> >> network."
R
#10
The NIC driver or router firmware may need to upgrade. To confirm it, please
post the result of ipconfig /all after it is local only.
"dbcarolina" <dbcarolina@xxxxxx> wrote in message
news:E9C2A585-C5D0-4F15-9BFF-B95B48863A83@xxxxxx
> then
> for
> thanks
>> >two
>> > security
>> > during
>> > the
>> > worked
>> > november
>> > 2008.
>> > it
>> >> > posting
>> >> > failure
>> >> > yesterday morning.
>> >> > which
>> >> > router.
>> >> > TIA
>> >> > Nick
>> >> wireless
>> >> NIC.
>> >> let
>> >> it
>> >> Broadcast
>> >> network."
#11
The Solution--At least mine.
Ok, so I have been over, under, and through every forum concerning this issue. Tried everything: resetting adapter, refreshing ipconfig, disconnected and restarted all equipment, reinstalled drivers, factory reset router. Nothing seemed to work, until I came across a post that said to set your ip address yourself. So here's what you do:
1.Go to network and sharing center (right click on your connection icon, lower right on screen, click network and sharing).
2.Click on Manage Network Connection to the right of this window
3.Now right click on the adapter you are trying to use and select properties.
4.Click on ipv4 Internet and click properties
5.Ok, so now you need your routers IP, you can get to this if you have access to the router. I have a netgear router and set the following:
IP Address 192.168.1.3 (The reason the end is 3 is so it doesn't conflict with my other computer)
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
Preferred DNS: 192.168.1.1
I'm pretty sure these are the same for most routers, but I could be wrong. Double check by googling your router or just by accessing your router. i.e. for netgear, it is routerlogin.net.
After you change all these things manually you should be up and ready to go.
One more thing: PASS THIS ON. There are so many frustrated people in forums, and looking for a solution to this stupid Vista Problem(the people at microsoft should really fix this.
#12
Re: The Solution--At least mine.
I have been having the same problem (connected to network, Local Only), and I just tried these steps and still no connection....I'm getting so frustrated that I might just reformat my laptop...
