Vista Network periodically freezes
johnromer
2
Hi all,
I have 3 PCs connected in a network by a Linksys Wireless G router:
  • 1 Desktop, connected by Ethernet cable
  • 2 Laptops, connected by wireless
They all use the Public folders on the desktop as a way to store common files. The problem I have is that the network allows access to the Desktop public folder,s but seems to freeze for about 30 seconds, unpredictably every 2-10 minutes, then start working normally again for a variable period.
During the freeze on access to the desktop, all PCs continue to be able to access the Internet without any problems. On the Vista Network page all 3 PCs are displayed
All 3 PCs are running Norton 360 Anti virus and Firewall, with the other PCs set up for Full Trust. If I turn off Norton 360, the problem does not seem to disappear.
I would be grateful for any help anybody can provide. Thanks - JR
142
Location
Oakland, CA and Germany
Have you checked the event log to see of any messages were logged about the problem from the system
    Sony Vaio
    Intel Core 2 duo
    ATI Mobility Radeon™ HD 3400 Series
    1600x900
    400 GB
    Laptop
    DSL 2 Mbps in dec 16 yesssss
    We Can DO I.T.
142
Location
Open Event Viewer - Windows Vista Help
im in germany and sometine my spelling is not so good thats why i gave the link
anyway check the event log for any kinda network related problems ie TCP/IP, NIC drivers, Netbios, etc and try and start from there to see if you trace the problem
    Sony Vaio
    Intel Core 2 duo
    1600x900
    400 GB
    Laptop
    We Can DO I.T.
