vista num lock after sleep and on welcome screen
T
Tiberius
there was s registry edit for XP that let you define the num lock state
before login..
in Vista the same registry path does not exist, also no MS article seems to
mention this...
so how can someone define it in Vista???
Please dont say anything about the BIOS... ok? It has no setting in the
bios.. this is
a windows configuration.
"Tiberius" <J@T.K> wrote in message
news:esUTdPjlHHA.4684@TK2MSFTNGP03.phx.gbl...
> before login..
> to mention this...
> bios.. this is
This would be the key that I would try, if I had the problem.
InitialKeyboardIndicators
at
HKEY_CURRENT_USER\Control Panel\Keyboard
from 0 to 2
as per this article
NumLock Key State Not Saved When Logging Off
http://support.microsoft.com/kb/123498
Jon
D
Dustin Harper
InitialKeyboardIndicators: REG_SZ: 0
Change it to a 2 to enable the NumLock on login. The key is in Vista.
Dustin Harper
dharper@vistarip.com
http://www.vistarip.com
> before login..
> to mention this...
> bios.. this is
Justinc
2
Hi, i am having the same issue as he is.
when i went into the registry to edit that key, there was no 0 there, it showed "2147483648".
Should i just change this to 2 or does the rest of that string have anything to do with it?
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
before login..
mention this...
bios.. this is
Posted by Justinc
Hi Tiberius and Justinc,
This tutorial will show you how to enable or disable the Num Lock key the way you want it.
http://www.vistax64.com/tutorials/91086-toggle-keys-startup.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
