Vista printing to shared XP printer
M
Michael
Configuration: HP Laptop with Vista Home Premium, Compaq desktop with XP home
and Epson Rx500 USB printer shared, Dell desktop with XP home. All in same
WORKGROUP.
Symptom: XP systems print to RX500 OK. When adding printer to Vista, sees
RX500 but get error message after "Connecting to RX500" box. Error messsage
says Windows cannot connect to the printer. Access is denied.
Thanks for your recommendaitons.
Michael
L
longvale
Hi this is a response I found on VNUNET.Com from a Robert Clayton which
worked for my situation which is similar to yours. I tried to access a
printer on my XP Home machine in another room via a wLAN, from my Vista
desktop. Constantly had a "cannot access printer" message until I followed
the instructions from Bob Clayton. Seems Vista will only access a 'local
printer' not a network one. From memory I needed to download the latest Vista
compatible driver for the printer attached to the XP machine, onto my Vista
machine before I took the steps below.
"Posted: 05-Aug-2007 19:09 Reply
Been trying to connect my wifes new Vista laptop (yuk) to print out to my
networked XP desktop's printers. I could see the files and printers on the XP
machine from the laptop. Tried all the usual , firewalls,file and printer
sharing turned on. Would not connect !
Apparently this is a problem that hasn't been solved.
This "workaround" solved it for me.
1.) Verify that File and print sharing is turned on and properly configured
on the XP machine.
2.) Locate and notate the Win XP computer name (i.e. "Desktop") (Found in
System Properties in the Computer Name tab)
3.) Locate and notate the printer share name on the XP computer (i.e.
"Printer") (Found under the Sharing tab on the Printer Properties page)
4.) On the Vista machine launch the "Add a Printer" wizard
5.) Choose "Add a local printer"
6.) Select "Create a new port" radio button and choose "Local Port" from the
drop down menu
7.) Press Next
8.) In the "Enter Port Name:" box enter the following: \\Desktop\Printer
where "Desktop" = the computer name from step 2 and "Printer" = the printer
share name from step 3.
9.) Select the Printer driver from the list provided or use the "Have Disk"
button to install the correct Vista driver if it is not in the built-in list.
It is critical that the driver you use is Vista compatible.
10.) Press next
11.) Give the printer a distinct name and choose whether to set as the
default.
12.) Press Next
13.) Print a test page to verify functionality.
14.) Press Finish
Hope this helps someone else.
Bob "
Let us all know if it works??!!
> WORKGROUP.
> Michael
M
Michael
Awesome....it works. First I had to connect the USB Epson RX500 to the Vista
Laptop to download drivers from Microsoft...per directions on Epson's site.
Go figure...Epson does not have the Vista drivers on their site. Anyway after
installing the drivers I put the printer back on the XP system and followed
your instructions. It works.......
THANKS!
Michael
I prefer RSX-11 Operating System!
> on the XP machine.
> drop down menu
> 7.) Press Next
> 10.) Press next
> default.
> 12.) Press Next
> 14.) Press Finish
> Bob "
> > WORKGROUP.
> > Michael
J
Joshua
I have tried this entire scenario and it still will not work. I have a
Lexmark z715 printer connected via USB to a workstation with XP home loaded.
I am trying to share the printer to a new laptop with vista home premium
through the wireless router. I was getting access denied, until I booted to
safe mode on xp home workstation and enabled the gues accoutn. Now i get an
0x00000d error when trying to connect to the shared printer. What am I doing
wrong?
> THANKS!
> Michael
> > on the XP machine.
> > drop down menu
> > 7.) Press Next
> > 10.) Press next
> > default.
> > 12.) Press Next
> > 14.) Press Finish
> > Bob "
> > > WORKGROUP.
> > > Michael
A
Alan Morris [MSFT]
E:\>winerror 0x0000000d
13 ERROR_INVALID_DATA <--> No NTSTATUS matched
I'm assuming you running with this Lexmark driver on the Vista machine.
Host based printers will be the hardest to deal with since the physical
device has limited capacities and the real bulk of the operational tasks are
performed by the software. Typically this is why host based devices are
less expensive than devices that support a standard print language like PS
or PCL.
Release Notes
Attention: To prevent issues during the installation, please uninstall
all previous versions of this driver prior to installing this web package.
File Information
File Name: cjrZ700-P700EN.exe
Version: 1.0.3.1
Released On: APR 30 2007 00:00:00
File Size: 38528944 KB
Products: Lexmark 710, Lexmark P705, Lexmark P707 Photo Jetprinter,
Lexmark P708, Lexmark Z705, Lexmark Z708, Lexmark Z715
Languages:
Operating Systems: Windows Vista
Application: n/a
Owner Name: Lexmark
Data Stream: Lexmark Host Based Solution
Security:
Install Instructions:
Related Links
Technical Support
and this driver on the XP machine
Download Now (Please allow pop-ups in your browser for this website)
CJB700EN.exe: Driver for Windows XP and Server 2003
Release Notes
Lexmark Z700/P700 Series Printer Driver for Microsoft Windows XP and
Server 2003. Certified for Microsoft Windows XP
File Information
File Name: CJB700EN.exe
Version: 1.0.11.0
Released On: MAR 17 2004 00:00:00
File Size: 16092160 KB
Products: Lexmark P704, Lexmark P705, Lexmark P706, Lexmark P707
Photo Jetprinter, Lexmark Z705, Lexmark Z708, Lexmark Z715, Z700 Series
Color Jetprinter
Languages:
Operating Systems: Windows 2000, Windows Server 2003, Windows XP
Application: n/a
Owner Name: Lexmark
Security:
Related Links
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"Joshua" <Joshua@xxxxxx> wrote in message
news:794C7857-6AE2-4E22-9179-7A856FE286B5@xxxxxx
> loaded.
> to
> an
> doing
> wrong?
>> Vista
>> site.
>> after
>> followed
>> THANKS!
>> Michael
>> > followed
>> > 'local
>> > Vista
>> > Vista
>> > my
>> > the XP
>> > printer
>> > configured
>> > on the XP machine.
>> > in
>> > from the
>> > drop down menu
>> > 7.) Press Next
>> > \\Desktop\Printer
>> > printer
>> > Disk"
>> > list.
>> > 10.) Press next
>> > default.
>> > 12.) Press Next
>> > 14.) Press Finish
>> > Bob "
>> > > XP home
>> > > same
>> > > WORKGROUP.
>> > > sees
>> > > messsage
>> > > Michael
J
Jammal
Man That worked Great thank you so much, I have spent the last 24hrs trying
to get my HP PSC 1209 to work on my New HP Vista Laptop. You just save me
$200. Thanks again
Jammal
> on the XP machine.
> drop down menu
> 7.) Press Next
> 10.) Press next
> default.
> 12.) Press Next
> 14.) Press Finish
> Bob "
> > WORKGROUP.
> > Michael
E
esroinc
I spent 4 hours with Canon this afternoon trying to get Vista to print
on my XP machine which has a Canon i950, over my network - No luck,
Canon gave up. Hung up, and looked at this Group. The above worked!!!
B
Bob F.
#8
Please include enough of the previous message(s) so that others trying to
follow this thread know what you are talking about. Also please try to
"edit out" the non relevant portions. It helps everyone. Go to:
Tools > Options > Send > check - "Include message in reply"
BobF.
<esroinc@xxxxxx> wrote in message
news:d95b3e5b-35b1-46c1-81af-afc622bc632a@xxxxxx
Just an inquiry, does this information mean that it is 100% possible
for printers to be shared from winxp = where the printer is directly
connected (host pc)
and winvista being the client pc?
Or it depends on supported printer/multifunction device?
B
Bob F.
#10
JT,
“edit out†the non relevant portions. It helps everyone. If you are using
Windows Mail, Go to:
Tools > Options > Send > check - “Include message in replyâ€
Regards, BobF.
"jt" <jt@xxxxxx> wrote in message
news:B84D9CB6-1596-4697-AE45-2914795F6CE8@xxxxxx
> connected (host pc)
A
Alan Morris [MSFT]
#11
It depends on the device, the device driver, the network configuration, the
security configuration, and the antivirus configuration.
Alan Morris
> connected (host pc)
M
MNielsen
#12
Hi, I have the same situation and I'ved tried the walkaround posted here
but it doesn't solve my issues.
Situation:
Xp Machine connected to network with printed attached and set to be
shared, also File & Printer Sharing is allowed through windows fire wall
(McAfee is completely turned off)
Vista machine connected to network, File & Printer Sharing turned on
and allows through windows fire wall (no extra security software
installed on this machine). Also printer vista driver is installed.
I've run the Add Printer wizard and follows the instructions posted
here but get stuck at the "Naming" of the new port. I get the error
message 'Network Path not Found'.
The shared printer is a HP DeskJet 3740 series.
My network is a standard network. Wired and wireless (Xp machine is
wired, Vista machine is wireless).
Any suggestions?
MNielsen
MNielsen's Profile: http://forums.techarena.in/members/mnielsen.htm
View this thread: http://forums.techarena.in/vista-print-fax/919548.htm
P
Patrick C
#13
Wondering if you have UAC off? See Sam's post;
"Hi all. Well I finally found the answer. I found another person on the
net who had the same problem and someone posted and gave the answer.
That person had uac off like me and the answer given was. You cannot
install a network shared printer with uac off. So I turned it back on
and it worked. Hope this helps someone.
SamG"
"MNielsen" <MNielsen.3ilbrc@xxxxxx> wrote in message
news:MNielsen.3ilbrc@xxxxxx
> Situation:
> Any suggestions?
> MNielsen
K
Kenyan_Geek
#14
IMPORTANT: Make sure "Enable Bidirectional Support" is DISABLED by unchecking
the box. Do this for both computers.
> on the XP machine.
> drop down menu
> 7.) Press Next
> 10.) Press next
> default.
> 12.) Press Next
> 14.) Press Finish
> Bob "
> > WORKGROUP.
> > Michael
