Vista screensavers not working
C
cjennings42
I recently had to reinstall Vista 32 bit on my PC & my screensavers do not
work,
I am using default drivers for wireless combo & screensavers worked before
reinstalling. My power settings do work however; is there a fix to this or
do I need to wipe PC & reinstall OS?
M
Mike Hall - MVP
"cjennings42" <[email protected]> wrote in message
news:[email protected]
> work,
> or
You need to get this optional update from Windows Update..
Microsoft - Other Hardware - HID Non-User Input Data Filter
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default.aspx?pr=newswhelp&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
M
Marty
Where can I get this update? There is no option on my Windows Update for
Other Hardware? Windows update in Vista looks like part of Vista where in XP
it was obvious I was in a web app with reasonable menu selections and info
available. (I really hate Vista, it has caused me nothing but problems.)
Marty
> > work,
> > or
> Mike Hall - MVP
t-4-2
Banned
Marty
> > work,
> > or
> Mike Hall - MVP
> Help US help YOU - Making good newsgroup posts:
> How to Use the Microsoft Product Support Newsgroups
> Mike's Window
Helloo Marty,
Google in the search box for Intellipoint softeware.( Make sure you ask for either 32-bit 0r 64 bit ). Install it and then look for the optional update " Hid Non-user Input Data Filter ".
T
T.
where can the update be found?
> > work,
> > or
> Mike Hall - MVP
B
bdenley
Mike:
Sounds great but I have not had a screen saver for years and MS has no fix
that I can find. I have a Dell Bluetooth keyboard and mouse and the last
Vista service pack ended my screen saver mode for good. I have installed
every MS update that has come by. Is there a link to this HID Non-User
Input data Filter? There are many thousands of us with this problem and MS
hasn't done much to help. I have searched message boards many times
looking for that fix and other than having a lot of company, I have not seen
a fix that has worked.
Brian
Brian Denley
http://home.comcast.net/~b.denley/index.html
"T." <[email protected]> wrote in message
>> >not
>> > work,
>> > before
>> > this
>> > or
>> Mike Hall - MVP
