vista settings
T
Tom McDonald
I have couple questions about settings/tweaking in vista. Does anyone know
what the values mean for superfetch in the registry? I know that the
enableprefetch has settings of 1, 2, or 3 meaning off, boot files only, boot
and application. Is it the same for superfetch? Is there a way to customize
the toolbar on windows explorer like you can in XP. I usually added an icon
for cut, copy, and paste but I don't know if it can be done in vista? Also
can you make a global change to the view setting for folders? I like all of
my folders to be in the List View. I tried using the folders options and
selecting apply to all folders like I did in XP but that doesn't work.
T
Tom McDonald
I got the views working but still no info on superfetch.
"Tom McDonald" <tmcdonald@satx.rr.com> wrote in message
news:230FB6AC-6A49-4DB6-B7CD-BD8E6077BAD2@microsoft.com...
>boot and application. Is it the same for superfetch? Is there a way to
>customize the toolbar on windows explorer like you can in XP. I usually
>added an icon for cut, copy, and paste but I don't know if it can be done
>in vista? Also can you make a global change to the view setting for
>folders? I like all of my folders to be in the List View. I tried using the
>folders options and selecting apply to all folders like I did in XP but
>that doesn't work.
