Vista shutdown defaults to sleep
T
Tony Rizz
Hello all
How can I change the default shutdown to shutdown and not sleep.
When I go to start shutdown the shutdown window comes up defaulted to sleep
where do I change this setting.
Also I can't change the default home page in IE how do I do this.
Thanks
t
B
Buddha Pest
Tony, I deleted mine but I was getting same thing you describe before I did.
I would tell Vista to shutdown, immediately get a black screen, and then
gibberish all over the screen. Then I would have to manually shut down my
computer. Upon turning the computer on, Vista would report that it was
waking up from sleep. Then I decided to delete it. Will wait for RC1 and 64
bit (I hope).
"Tony Rizz" <tonyrizman@hotmail.com.com> wrote in message
news:%23j6Wvj8yGHA.996@TK2MSFTNGP03.phx.gbl...
> Hello all
> sleep where do I change this setting.
> Thanks
> t
T
Tom Ziegmann
Hello,
To change the default behavior of the "power" button, open the control panel
and select power options, Then on whichever power plan you are using, click
on edit plan settings, then click on Advanced Plan Settings and you can change
the button option from there.
Tom Ziegmann
Microsoft Certified Professional
Windows Vista / Server Longhorn Technical Beta Tester
Windows Server 2003 Service Pack 2 Technical Beta Tester
> I did. I would tell Vista to shutdown, immediately get a black screen,
> and then gibberish all over the screen. Then I would have to manually
> shut down my computer. Upon turning the computer on, Vista would
> report that it was waking up from sleep. Then I decided to delete it.
> Will wait for RC1 and 64 bit (I hope).
>> Hello all
>> Thanks
>> t
D
David Wilkinson
Tony Rizz wrote:
> Hello all
Tony:
Yes, this is extremely annoying. Why doesn't it default to the last
action selected?
David Wilkinson
