Vista stuck in "Basic" theme
Flamzeron
I downloaded an MMORPG called "Return of Warrior" a while ago, and it worked just fine. Whenever I would play a game in full screen, Vista would go into the Basic theme to run better (I assume, though I could be wrong) and when I was done playing the game it would go back to my Aero theme. I tried running Return of Warrior, and I got past the login window before the game starts, but then the whole thing didn't respond and exited out, leaving me in the Basic theme. I've tried restarting my PC 3 times already, but that doesn't work. I also tried using the Task Manager to end the process, but I couldn't figure out what it was I needed to end (I tried ending something called "winlogon.exe" but it wouldn't let me). I also tried uninstalling Return of Warrior, but that did not do anything. I even tried going into the Control Panel and manually switching the theme back, but Aero didn't show up?
What should I do?
richc46
Could be a ram problem. Go to search and type memory diagnostics and run the test
Go to device manager update video card and driver.
If you do not have sufficent ram Aero will not work.
Flamzeron
I did the test and it said that there were no memory errors.
What do I click on when I'm in device manager? I see several things. Here's a pic if it helps.
richc46
Flamzeron
It worked! Thanks a lot! My aero is back.
One more question. I messed up my username on this forum, and I wish it to be something different. How would I go about doing that?
richc46
I will post your question with management and get back to you.
Im glad about your Aero.
richc46
I sent it to the top. Come back tomorrow, you should have an answer. Night. Glad that the aero problem was resolved.
richc46
I think flamzerom is cool.
Brink
Staff member
mvp
Hello Flamzerom,
What would you like your user name to be instead? :)
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Flamzeron
Hello Flamzerom,
Hi!
I would like my name switched to "Flamzeron" please. The only difference is that I replaced the "m" with an "n", like how I had originally intended.
Brink
Staff member
mvp
Done. ;)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
richc46
Well Flamzeron, everything seems to have worked out for you. You have your Aero back and a name change. I hope that you remember us, and return, the next time that you have computer problems or have information that can benefit others.
Thanks for your help Shawn.
