Vista Taskbar now a light gray
McCheesy
3
I am running Vista Home Premium, and when I turned on my computer, my taskbar was a light gray. I took a picture:
If I open a full screen window (such as Firefox), my taskbar goes back to the normal black color, but if I don't have a full screen window it is that light gray color.
How can I change it back?
Barman58
Staff member
1,784
Location
Newport, South Wales, UK
Hi McCheesy, and welcome to the vista forums, :party:
it's a little difficult to see exactly from the image you attached but it may just be a result of the Transparency level you have set.
right click on your desktop choose Personalise, then Window colour and appearance, and adjust the intensity slider,
see if that changes things.
also check the selected colour and use transparency box
hope this helps
  • Show second system?
    No
    Operating System
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
McCheesy
3
None returns me to the original black color. I think it might have been because I uninstalled HP Total Care Advisor. Do you know where I can find that program again?
Barman58
Staff member
1,784
Location
I know that MS included an update to it's nVidia drivers this week - if you downloaded that you may want to check if the settings have changed in the advanced - nvidia control panel
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
Barman58
Staff member
1,784
Location
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
smarteyeball
Eye know, eye know
1,874
Location
Australia
It's hard to tell from the picture, but it looks like it's switching to a basic theme. When you start FF it may be triggering WDM which returns the Aero-translucency theme. Maybe it's an older app on start-up that is switching off aero.
Just a thought.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
#8
Hello McCheesy, welcome to Vista forums!
You don't have a problem, that's the way mine does also.
When I don't have a window maximized it's gray, when I maximize it turns black.
Try this: with no windows maximized slide a window under the taskbar to see the transparency.
The transparency lessons when you have a window maximized!
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
9
#9
I have the same problem: Gray taskbar when windows are either restored or minimized and black when maximized. I like the black and hate the gray (a.k.a. "graphite"). Is there a way to adjust settings so that will keep it the black style all the time? The graphite looks bad with my desktop wallpaper, but the black would look good if I could keep it that way.
    Home built
    Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz (4CPUs), ~2.8GHz
    Gigabyte EP45-DS3R
    16382MB RAM (G. Skill 800MHz 16GB)
    NVIDIA GeForce GTX 260 Integrated RAMDAC 2928 MB (evga)
    Onboard (optical cable used for output, 1/8 jack ins)
    Samsung SyncMaster 275T+ (27" SPVA panel) ; Dell 17" CRT monitor
    1920x1200 plus 1600x1200
    Seagate (latest as of 4-25-09) 1TB, 1.5TB, 1.5TB
    Western Digital My Book eSATA external single-drive 1TB
    iOmega PATA/IDE 120 GB (usb external)
    Corsair 750w
    Coolermaster Stacker 810
    Noctua NH-U12P processor cooler (heat sink/120mm fan)
    Logitech cheap wireless keyboard/mouse combo and PS2 ball
    Logitech cheap wireless keyboard/mouse combo and PS2 kybd
    DSL; GoldenWest Telecommunications; 1.5MB down, 750K up
    Hauppauge 1800 TV card/remote (PCI - not express)
    old 4-port PCI to USB card
    Rosewill multifunction SDHC and others card reader/usb port
    Brother MFC-6490CW wireless multifunction printer
    HP deskjet 940c printer
    Lexmark x83 multifunction printer
    Linksys WUSB54GSC compact wireless-G network adaptor
    Technics SA-DA8 receiver
    Infinity SM-125 speakers
    ASUS M50V laptop
mansrm81
1,884
Location
Rockford, IL
#10
Do you have the color intensity turned up all the way
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
9
#11
Yeah, unfortunately this isn't something that can be fixed on the screen that includes adjustment for color intensity.
When a window is maximized (from any program), the taskbar looks like this (and the title bar and sides too):
Black:
This black look is what I like. It works well with all of my programs and skinable applications.
When there are no windows open (just blank desktop) or when windows are minimized or restored (not maximized), I get this gray "charcoal" theme, which I do not like:
Gray:
This switch in color happens every time I change from maximized window to non-maximized, regardless of settings of the color intensity and regardless of what program I'm using.
If at all possible, I would really like to just keep it black and not see the gray theme at all.
    Home built
    Gigabyte EP45-DS3R
    Corsair 750w
    ASUS M50V laptop
Bare Foot Kid
2,616
Location
The Lowcountry
#12
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
9
#13
Disabling Aero sadly keeps it always gray instead of always black. :(
I guess I have to either just deal with it or go with third party skinning.
    Home built
    Gigabyte EP45-DS3R
    Corsair 750w
    ASUS M50V laptop
Bare Foot Kid
2,616
Location
The Lowcountry
#14
Hello again.
Sorry that didn't work for you; but thanks for posting back with the outcome.
If you find a program that does work for you be sure and let us know.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
#15
I did not even notice this gray/black taskbar until now.
Well, my HP is 5 wk old , still with hardly unchanged default settings (the only change I have done is startup program trimming for quicker start/reboot).
Now, I have become fully aware that taskbar is gray if only one down-sized window is running which is contrasted in dark bar. With full screen sized solo window running, taskbar is black and window is blended in black bar with bright white fonts. No big deal....until you multi-task. Check this out!!!
With multiple running windows, this gray/black transformation proves to be evidently a smart (albeit, nuanced) VISTA feature. When windows are all down-sized, taskbar is gray and only front window is contrasted in black bar that makes white fonts brighter, while all background windows are blended in separate individual gray bar that makes fonts less bright. When one or more windows are full screen sized and one or more are not, taskbar turns black with all background windows in contrasting gray bars with less bright fonts while front window is blended in dark bar with brighter fonts.
Furthermore, when "switch between windows" feature is activated (quick launch)to cascade all running w's (in 3D), taskbar is black and all windows are contrasted in gray bars with faded fonts.
I am convinced it is a very smart default setting. I would not change it a bit for the world.
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
OzRob
1
#17
I had the same problem, and had found out the culpret.
I recently install Nero and found out by using windows defender to close all startup programs down, then rebooting to see if that fixed the problem.
Yes after quite a few reboots I found it to be Nero's InCD that caused the conflict, Simply disable it and that I'm sure will fix your problem.
If you dont have nero installed it could be a conflicting program, do as above until you find the offending program.
By the way if you have Nero installed and find it to be your problem, please email nero and ask for a fix, as they wont do anything untill the have several complaints,
Hope that help you Rob
staka
3
#18
For me though.. it was the Google Sidebar that came installed with my Dell Laptop.
I uninstalled it and turned gray, but when I reinstalled it.. turned back to normal black.
Disabling this Sidebar will make it gray as well... it has to be on desktop.
But I hate Google Sidebar.. so no idea what else I should do to fix.
akrobet
7
#19
I think I have found the solution. Disabling Aero itself doesnt help, that's when we get the pale grey color.
Instead, we have to reset the Windows Vista Basic color scheme.
Here is how to do it:
1. Go to Personalization
2. Windows Color and Appearance
3. Click on "Open classic appearance properties for more color options"
4. Set the color theme to Windows Vista Basic.
Although, from now on, I have the old dialog box for the colors, haven't found a way to change it back to the new Vista style, but frankly, I don't give a damn, I just want it to be black everywhere :)
staka
3
#20
Oh wow..... Wow. It works! Thank you so much.
Although the windows look retarded with blue.. but oh well. At least bottom is black.
