Vista Updates not displayed in Installed Updates
davisj01
I apply MS Updates regularly and have no updates outstanding apart from two optional updates that I don't intend to install. However, when I visit >Programs and Features>View installed updates no Vista security updates are shown. The only updates displayed are those for M$ Office etc. The freeware product System Inspector for Windows shows Vista security updates as installed correctly! I have run the Fix It utility provided by Microsoft with no joy.
Any ideas?
    Dell Inspiron 530 desktop
    Intel Core2 Duo E4400 2.00 GHz
    2.00 Gb
Katokato
Banned
Run the updater again.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
davisj01
Hi Katokato
Tried that but no luck. Update History reports updates as installed successfully but they don't show up in Installed Updates. I use a freeware product System Inspector for windows and that does show the updates as installed. Installed Updates doesn't show any new updates after 10/3/2010 although I have run Windows Update several times since then. It seems updates are being applied but there is some sort of glitch in Programs & Features.
    2.00 Gb
davisj01
Hi Flavius
Thanks for your response.
I have run System Update Readiness Tool for Windows Vista (KB947821) [January 2010]. I will use rapidshare to upload the files so will need youe email address. Thanks
    2.00 Gb
Flavius
Expelled
Hi Flavius
You don't need any e-mail address!When you'll upload all files rapidshare site show you link to hosted files.Paste this link here and ready.
davisj01
    2.00 Gb
Flavius
Expelled
davisj01
Hi Flavius
Thanks for your help. It is as I feared, that I will need to re-install.
You've suggested that I carry out a repair reinstall. My computer is a Dell Inspiron 530 with Vista Home Premium and 250Gb HDD RAID1. Dell provide a factory reinstall feature from a separate partition on the HDD, and I wonder whether that would be good option.
My HDD is a 250 Gb HDD with a second HDD using RAID 1 to create a mirror disk. The primary disk has three partitions as follows C: D: = Dell Backup, and E: = Dell Recovery. The D: partition is used by Norton Save and Restore for local backups; I don't use the E: partition at all so it should still contain the Dell factory image. Btw, I assume that when factory settings are restored this includes any pre-installed applications.
I have never reinstalled Vista and before I do so I would like get answers to the following questions:
1. Will a factory re-install reformat the C: drive only or the whole HDD?
2. Will a factory re-install restore the system exactly as was on delivery including all pre-installed applications such as MS Office, McAfee, and Norton etc.?
3. If a re-install preserves the D: Backup partition will it be possible to retore folders and files from there or will the process of recovery affect Norton Save & Restore settings in such a way that the application will no longer be able to 'see' existing backups? In other words will the process of restoring the C; drive affect Norton in any way. For example, if Norton is restored on the C; drive as a result of the factory re-install, are there any Norton files on the C: drive that will be overwritten by a re-install, thus preventing Norton from 'seeing' the pre-existing backup files in D:?
I look forward to receiving any help and advice you can offer.
    2.00 Gb
