Vista Will Not Start!
W
Weifert
I'm using Vista Home Premium...One day I restarted my Acer Aspire 5630 and I
got a black screen with the message:
Windows failed to start. A recent hardware of software change might be
the cause
So I run Startup Repair, and it says "Startup Repair cannot repair this
computer automatically." Under the diagnostic and repair details it says the
root cause is that the system volume on disk is corrupt.
I booted directly to the DVD with the exact same result.
This is driving me up a wall and making me hate Vista... so if there is
anybody out there who can help me on this I would really appreciate it.
R
Rick Rogers
That's a hardware problem, not a Vista problem, the file system is munged
and the hard drive cannot be loaded. Often times, this is only resolved by
recreating the system volume and starting from scratch. Boot from the DVD
and try running a chkdsk /r from the recovery environment (choose the
command prompt option), see if it can fix the drive. Otherwise, you may have
to go the long way 'round. Hopefully you backed up your data on a regular
basis.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Weifert" <[email protected]> wrote in message
news:[email protected]
> I
> the cause
> the
A
AJR
Weifert - Run "Startup Repair" several times - there are instances involving
several causes and startup repair may treat them individually and not as a
group.
> I
> the cause
> the
tsun
Hi, I have the exact same problem, and i'm well aware that this is not a vista problem, however I cannot find a fix to this problem anywhere. I was wondering how to start it up with the DVD? I was only given a windows upgrade CD with the laptop and i've tried the chkdsk /r method (tells me the thing is in use and to try again) as well as repeatedly pressing the repair button.
Brink
Staff member
mvp
Hi Tsun,
Welcome to the Vistax64.com forum. :party:
I would recommend doing a Repair Install to see if it will fix your problem. This will allow you to repair your Vista installation without loosing your files, settings, and programs. You can see how to do it in this tutorial.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
tsun
I thought this wasn't a vista problem?? also, I can't complete the repair because I did not get the dvd or cd with my laptop
Brink
Staff member
mvp
"brink" wrote:
Hi Tsun,
Repair Install For Vista
Tsun,
Technically it is a corrupted hard drive problem. The repair install is a option to try to repair the corruption damage instead of formatting the hard drive and doing a clean install. If you have a friend with a Vista installation DVD, you can borrow it to do the Repair Install. You just will need to enter your product key during it.
    Lumia 1520 phone
