Vista will not wake up from sleep mode
T
T&V Seitz
Vista will go into sleep mode Ok, and initially I was able to get it to
recover from sleep mode properly. Then I added an additional gig of ram,
for a total of 2. I have an Acer ase 380 PC. After adding the ram, the PC
will no longer recover from sleep, neither mouse nor video comes back on.
Any ideas would be appreciated
J
John Hanley
I am also having similar problems with Vista sleep. I bought the HP
Pavilion computer on May 25, and sleep worked until June 13, not aware what
might have changed. Mine will not wake up properly either; the screen is
dark, and the keyboard and mouse inoperative. It will (after a few minutes)
give the BSOD, then reboot itself. I have unchecked and changed many things
as suggested in various forums, but no permanent solution. I am doing
without (i.e. not permitted it to go to sleep & turning it off totally for
overnight).
D
dmrdm
Has Microsoft come up with a solution for this yet? Shutting down everytime
I leave the computer just isn't realistic with the number of times I get on
and off of it. The manufacturer has not been any help yet.
Someone told me that they had the same problems and replaced their power
source and now it works fine. My manufacturer has not recommended that yet.
None of the tech people we talked about seemed to have heard about the
problem even though there are hundreds of threads on the internet about it.
(new computer with Vista)
"T&V Seitz" wrote:
P
Phillip Schulte
I have an HP and its giving me the same problem...I am tired of turning my
computer off and on to get it out of sleep mode. I hope Microsoft fixes this
problem soon. I will continue to search the internet to see if anybody else
has been able to resolve this problem.
P
Phillip Schulte
Hi Ian,
I copied this from the below link. I hope this helps you...If not, you might
have to turn off sleep mode altogether.
Good Luck,
Phillip
http://support.microsoft.com/kb/930091
A Windows Vista-based computer does not resume from sleep mode if you move
or click a USB mouse as the computer is entering sleep mode
View products that this article applies to.
Article ID : 930091
Last Review : March 15, 2007
Revision : 1.4
SYMPTOMS
Consider the following scenario. You have a universal serial bus (USB) mouse
connected to a Windows Vista-based computer. You move or click the mouse as
the computer is entering sleep mode. Then, after the computer has entered
sleep mode, you try to resume the computer by using the mouse or by pressing
a key on the keyboard. In this scenario, the computer stops responding
(hangs) at a black screen.
Back to the top
CAUSE
This issue occurs because some USB mouse devices do not work correctly with
sleep mode in Windows Vista.
Back to the top
RESOLUTION
To resolve this issue, follow these steps:
1. Click Start, type device in the Start Search box, and then click Device
Manager in the Programs list.
2. In the User Account Control dialog box, click Continue.
3. In Device Manager, expand Mice and other pointing devices.
4. Right-click the USB mouse, and then click Properties.
5. Click the Power Management tab.
6. Click to clear the Allow this device to wake the computer check box, and
then click OK.
J
Jackie L
#8
I have a new HP computer and when I got it last week, it wouldn't wake up. I
called HP support (I wish they could speak English!) and eventually they gave
me this link:
www.sleep-fix.notlong.com.
I put that in my browser and it executed something. Waking up sleep mode
worked better for nearly a week (only had to reboot after all night), but now
it fails every time again. Any more ideas?
Thanks
#9
I have exactly the same problem as John Hanley T V Seitz with a compaq presario C714NR, After i upgraded the RAM from 1 GB to 2GB, sleep mode doesn't revive and sometimes does an awkward improper shutdown. HP customer support suggested that i need more compatible (MORE $$$$$ RAM) to solve the problem..and they're just being annoying without understanding the problem. I hope one of you guys come up with a solution. Philip and Jackie,,,the problem u're addressing is for encountering this problem when u're using a USB mouse. Not the original issue posted
F
frustrated
#10
I have a similar problem. When my PC goes into sleep mode it disables the
keyboard and mouse so I have no way to get it out of sleep mode. A hard
reboot wakes it up, but this is not healthy operation. I have run all updates
but no progress on this issue. Any suggestions?
D
DarkSentinel
#12
I have the same machine. Came with 2GB however. Have you set the mouse
and/or keyboard to be able to wake the machine?
Sanity calms, but madness is more interesting.
#13
Same here:
Acer 5100
Vista Ultimate x64
4 Gigs Ram
ATI Radeon Mobility Xpress 1100
Originally I had problems with XP and x32 video messing up after waking up from Sleep mode. I fixed the problem with updated video drivers. Now I'm using the most current 8.1 Catalyst drivers, and still no wakey-wakey.
B
Blackadder XVII
#14
I'm running a $4000 Asus computer with the works and that was the only
current working solution.
Have to wait until MS, Nvidia and Intel etc... get together and figure it
out.
#15
Yes, I did that and allowed Hibernate again. It had been disabled because I didn't have enough disk space left on the drive. Seems Vista takes up 22Gigs alone. Once I freed up some space, Hibernate was allowed again. But still no sleep mode.
#16
Likewise, I am frustrated. I have a brand new HP Pavilion Slimline Desktop and it will go to sleep and not wake up. HP support has suggested lots of things to try and so far none has worked. Microsoft does not seem very concerned or eager to help. I have disabled sleep mode until someone can find a solution.
TP
#17
Go to Advance Power Settings.
Set hard drive to turn off a minute or 2 before sleep.
Set Hybrid and Hibernate modes to "Off"
Under USB settings select "Disable"
Under Multimedia select "Allow ....."
#18
Brink
Staff member
mvp
#20
TP
Hi presdog,
You might try this to see if this can help you find your sleep mode problem.
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
