Vista/WMP11 MPEG-1 (50) Missing Codec Problem
S
Saidas
I just got Vista Home Premium and went to download files that I had no
problem doing with XP and I get:
"Windows Media Player cannot play the file (or cannot play either the
audio or video portion of the file) because the Microsoft MPEG-1 (50)
codec is not installed on your computer".
I've checked a few forums and evidently this is a wideapread problem
without a solution other than using another media player which I don't
want to have to do. Why is this even a problem since all are MS products
and Vista has been in release for some time now?
Does anyone have a fix other than my using Winamp? :(
Saidas
Posted via http://www.vistaheads.com
Z
zachd [MSFT]
That indicates that something likely stomped on the system's MPEG decoder.
What is listed under WMP's Help:About:Technical Support Information menu
tool's "DVD/MPEG filters" list?
Speaking for myself only.
See http://zachd.com/pss/pss.html for some helpful WMP info.
"Saidas" <[email protected]> wrote in message
news:[email protected]
> Saidas
Chronia
Did anyone ever find a solutions to this problem, becasue I am having it too. Files that played fine on XP now won't play in Vista. I don't want to switch media players, and renaming the file is not a solution. I have Vista hom Premium. I don't under stand any of the technical threads I've read all over the web. The replies in this thread also make no sense as I believe they are copies from other forums. Does anyone have a solution to this? I have tried downloading Vista Codecs Pack and that did not fix the problem.
If anyone has a proper solution that will allow me to run media player without renaming the files please let me know by replying here (local to this forum, mirrored and copied posts from other forums (such as in above posts) gets VERY confusing and causes a ALOT of unessecary jumping around). I'd appreciate it. Thanks
    HP/a6752f
    Intel® Core™2 Quad Processor Q8200 2.33GHz
    Asus IPIBL-LB
    4 x 1028 MB DDR2-SDRAM (PC2-6400/800MHz
    GeForce 9500 GS
    Realtek ALC 888S chipset (integrated HD audio)
    LG Flatron L206WtQ-BF
    168x1050
    WDC WD6400AAKS-65A7B0 640 GB SATA 3G (3.0 Gb/sec)
    hp PS/2 optical mouse
    HP Enhanced Multimedia PS/2 KB 0630
    Cable
