Vista won't see dynamic harddisk1 (not hd0), XPpro does. Any reaso
R
rgh1951
as the subject line says. boot and system disk are one and same harddisk 0
partiton 1 -= Drive C...
Vista will not see dynamic harddisk1, my second installed hard drive, which
is a synamic disk.
any dieas why?
R
rgh1951
> partiton 1 = Drive C...
> is a dynamic disk.
> any ideas why?
Typos corrected...
R
rgh1951
RE: Vista won't see dynamic harddisk1 (not hd0), XPpro does. Any r
I add that this applies to BOTH Vista Home Premium and Vista Ultimate...??
Why wouldn't Vista Ultimate recognize a single-partitioned dynamic-disk
second hard drive that XP pro sees and uses with no special configuration?
> > is a dynamic disk.
> > any ideas why?
> Typos corrected...
A
On Tue, 15 Jan 2008 07:08:00 -0800, rgh1951
>is a synamic disk.
>any dieas why?
Try the import foreign disks command in Disk Management.
is a synamic disk.
any dieas why?
Vista won't recognize a Dynamic drive. It will only allow you to convert it to Basic. If you do, you won't find your data there anymore. However, I've used "Active Delete Pro", which will recover the lost data. Better yet, it will allow you to put a "Mini-operating system" on a cd, restart, and transfer all of your data to another drive before you reformat to Basic.
Good luck with it!
