Vista x64 sp1 v.744 will not UNINSTALL
4
Keep getting this message every time I try to uninstall.
(service pack did not uninstall. reverting changes). Please help.
My system is a Dell with the OEM vista x64 Ultimate. I would like to install the new sp1 rtm.:mad:
joel406
Senior Member
471
Location
Reality
Use system restore. Hopefuly you imaged before installing. The warnings were as easy to see as the download was to find. You will probably need to reformat.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA
    1 250GB Western Digital SATA
    1 200GB Maxtor SATA
    2x160GB Western Digitals SATA
    1 320GB Seagate External
    1 120GB Western Digital External
    1 80GB Westen Digital External
    1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
4
I've been able to just uninstall service packs before with no problem. This should be no different. I do hope reformatting is not my last option. To many games to reinstall.
joel406
Senior Member
471
Location
Reality
You installed RC or beta and those have bugs. Uninstalling can be one. There are a lot of people that put betas and RCs on their systems looking for solutions to problems that were caused by other issues then the ones that are getting fixed in the final release of SP1.
Your probably screwed unless someone has come up with a uninstaller app that is capable of removing it. Like the Norton removal tool.
Consider using a app like Acronis. You could have imaged your drive before installing a beta app. Then when the final is released or you need to uninstall for any reson. you just run Acronis and revert your system back to before you installed the program. It does work for x64. I'm living proof.
    Intel DQ35JO
    1 200GB Maxtor SATA
    Antec
    Fresh Air
    Razer Diamondback
4
Thanks for the info. Hopefully someone will have a simple solution so I don't have to go through with all this reinstalling. So I'll be waiting and hoping. Maybe I need to uninstall some of those other updates after installing sp1 rc to get this sp1 rc to uninstall.
4
If I knew for sure that reformatting and reinstalling was my last option, I would go ahead and do so. I cannot believe their is no other solution to this. I will wait a few more days. Maybe someone will have answers. Reformatting and reinstalling, is just an easy answer to this problem. It's just a service pack that needs to be uninstalled and seems to get stuck during removal. :zip:
joel406
Senior Member
471
Location
Reality
Bad news Steamer2499. The Vista sp1 has a kernal update in it.
In short.
Your screwed.
sorry...
    Intel DQ35JO
    1 200GB Maxtor SATA
    Antec
    Fresh Air
    Razer Diamondback
