Visual Styles
M
Meaghan
I'm just curious, is there any to apply Visual Styles to Vista? I had
hundreds of visual styles when using XP but I can't figure out how to on
Vista. Any information would be helpful.
If that's not an option does anyone know where to download actual .theme
files, or is there any way to convert .msstyles to .theme? Thank you.
K
King Library
Right-click desktop, select Personalize, select Themes or Visual Styales or
somethinglike that.
"Meaghan" <Meaghan@xxxxxx> wrote in message
news:CD9FE0C2-023B-4ECC-9AAC-ABBEFD8C2FCF@xxxxxx
A
Access Services
something like that.
C
Clear Windows
you will need vistaglazz 1.1 beta (NOT 1.0!!!!)
http://www.codegazer.com/vistaglazz/downloads/ to enable vista to use third
party themes
and browse here for vista themes (called visual styles)
http://browse.deviantart.com/customization/skins/windows/visualstyle/?order=9&alltime=yes
(press the next page link on the bottom to see the whole collection, since
some are for XP and some for Vista, you need the ones that are specifically
made for vista)
