Visualize resolution
3vian
I've been trying to increase the full-screen resolution of 'visualize' without much success. I've openned up the the 64-bit version of WMP and changed the resolution in Tools - Plug-ins - Options - Visualization - Battery - Properties, but even in WMP that doesn't work and obviously doesn't work in VMC. Has anyone had an success in changing the resolution?
MrNeeds
PC Geek
everyone has this problem, the full screen resolution is an empty option, and has been since WMP9, if you want to enable full screen resolution for visualizations, you will have to download some plug-ins for visualizations.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
TranceMaster
But when I was running wmp11 with xp, the full screen resolution worked fine. I only had this problem after I installed vista.....
If I need to download some plugins, what plug-in do I need? Thanks for your reply, hopefully I can sort this problem out.
MrNeeds
PC Geek
i assure you it didnt, i have vista and xp on dual boot, the full screen visualizations were disabled in WMP9, they also got rid of a lot of visualizations from the database as well, i find that twisted pixel do a good visualization, which can be found here TwistedPixel™ plug-in for MediaMonkey, WinAmp, WMP & MCE
    16Mb Sky bb
TranceMaster
Yeah Thanks for the link, your the man.
I just reinstalled xp on my other computer and tried it on both wmp 9 and 11, and set the visualization to battery( some of the visualization you cant change the full screen resolution), the full screen 1920*1200 worked. but when I try wmp11 on vista, full screen resolution setting didn't change anything.
anyway, thanks for the link again.:D:D:D
