VMSMP Error 28
  • Thread starter Christian Trygve Erichsen
  • Start date
C
Hi there i have read you post on this error
Typical whit this error is when you are running a virtual server on 2 different servers you will get this error.
VMSPM error 28
Port 'DAC3B97C-9274-46F6-A097-05200E9B2E3B' was prevented from using MAC address '00-15-5D-10-FC-03' because it is pinned to port '1E2A1849-F339-4C93-96D7-BF75E016692D'.
I experience the same problem and found out what was wrong, I have 2 Hyper-V server setup for one of my costume, this error begin to pop up in the event log, i found out that the global MAC Network settings is the same for Both Hyper-V server, so by change the MAC in the Virtual networks manager, the error 28 stop running on both server, you will also need to reset you network card, to make it work.
PreventRage wrote:
Am now also getting this. On all 8 VMs running on a single Server.
27-Nov-09
Am now also getting this. On all 8 VMs running on a single Server. I believe
the badness started on 11/13 for me. Which may also have been the day I
switched all the VMs from using "dynamic" MAC addressess to fixed ones.
"Rickuk99" wrote:
Previous Posts In This Thread:
On Monday, October 26, 2009 4:56 AM
Rickuk99 wrote:
VMSMP error 28
Hi All
I have just started to get this warning
vmsmp id 28
Port 'E7DEFAC0-FAF7-4296-915C-C7742792BC83' was prevented from using MAC
address '00-1E-0B-90-F5-AA' because it is pinned to port
'SCVMM-678A6CA5-3691-43DE-8DCC-07884D8F'.
It is filling my event log as it is logged every second
On Friday, November 27, 2009 12:05 AM
"Rickuk99" wrote:
Submitted via EggHeadCafe - Software Developer Portal of Choice
Distributed Data Grids - Share Objects Between Windows Service and ASP.NET
http://www.eggheadcafe.com/tutorials/aspnet/953ed61f-e440-4ca5-8b7a-1bb00e33db07/distributed-data-grids-.aspx
D
dale1952
Is this true for Virtual Server 2005 Enterprise Edition?
TIA
<Christian Trygve Erichsen> wrote in message
news:[email protected]
> VMSPM error 28
> 27-Nov-09
> believe
> Rickuk99 wrote:
> VMSMP error 28
> Hi All
> vmsmp id 28
> believe
