VPN IPSec error 789
F
Franz Schenk
Try to establish from my Vista SP1 client an L2TP/IPSec connection to our
Windows 2003 IAS/RRAS servers. There is no NAT between client and server
- Have certificate based authentication, the machine certificate is
installed, with a valid certificate path
- IPSec connection to the same VPN server works fine with Windows XP
clients, and from a Windows XP VM hosted on the same Vista client
- Getting always error 789 when trying to connect
- Have googled, and the only hint was to try to clean boot Vista. Have done
this (disabled all 3rd party services in msconfig), but still have the same
problem.
- Have enabled diagnostic logging in Vista, but I'm unable to decrypt all
information. Below are some extracts of the Logs
Thank you all for any advice about this issue!
Franz
rasman.log
[1408] 07-24 14:22:50:956: EnableIpSec: port=VPN0-1, fServer=0, fEnable = 1,
rc=0x0
[1408] 07-24 14:22:50:956: DwDoIke: port=VPN0-1, hEvent=0x14ec
[1408] 07-24 14:22:50:956: IsIPAddress: 62.2.xxx.xxx is a valid IPV4 String
[1408] 07-24 14:22:50:956: IsIKESecureCheckDisabled: Destination address is
an IPAddress, Disable the IKESecurity Check
[1408] 07-24 14:22:50:956: DisableIKESecurityCheck flag is 1 and
IsIKESecureCheckDisabled returns with 0
[1408] 07-24 14:22:50:960: Found primary ip address for this interface.
wType=0x5,address=0x3d01a8c0
[1408] 07-24 14:22:50:961: DwGetBestInterface: done. rc=0x0,
address=0x3d01a8c0, mask=0xffffff
[1408] 07-24 14:22:50:961: DwDoIke: done. 0x0
[1408] 07-24 14:22:50:961: DwDoIke for port VPN0-1 returned 0x0
[1408] 07-24 14:22:50:961: DoIke done. 0x0
[3124] 07-24 14:22:54:523: BackGoundCleanUp
[3124] 07-24 14:22:54:523: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:04:523: BackGoundCleanUp
[3124] 07-24 14:23:04:523: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:14:523: BackGoundCleanUp
[3124] 07-24 14:23:14:523: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:24:523: BackGoundCleanUp
[3124] 07-24 14:23:24:523: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:34:524: BackGoundCleanUp
[3124] 07-24 14:23:34:524: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:44:524: BackGoundCleanUp
[3124] 07-24 14:23:44:524: OVEVT_RASMAN_ADJUST_TIMER
[3124] 07-24 14:23:54:524: BackGoundCleanUp
[3124] 07-24 14:23:54:524: OVEVT_RASMAN_ADJUST_TIMER
[1408] 07-24 14:23:55:958: DwQueryIkeStatus: retcode=0x0, status=0x78b
[1408] 07-24 14:23:55:959: DwQueryIkeStatus: Freeing IkeInitiateContext
handle 0x316a400
[5652] 07-24 14:23:55:961: ReferenceCustomCount
[5652] 07-24 14:23:55:961: ReferenceCustomCount done. 0
[5652] 07-24 14:23:55:962: RefConnection: 0xa0000
[5652] 07-24 14:23:55:962: refcount=0, maxports=6, ports=1
[5652] 07-24 14:23:55:962: RefConnection: ref on 0xa0000 = 0
[5652] 07-24 14:23:55:963: PortDisconnectRequest - calling
CheckIfAllowedToDisconnectOREnumerate
[5652] 07-24 14:23:55:970: DwSendNotificationInternal(DISCONNECTING)
returned 0x0
[5652] 07-24 14:23:55:970: QueueCloseConnections: no dependent connections
C:\Windows\tracing\tapi32.LOG
[1408] 14:22:50:846: [TRACE] DoFunc -- enter
[1408] 14:22:50:846: [TRACE] AllocClientResources: enter
[1408] 14:22:50:846: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:847: [TRACE] DoFunc: back from srv- return code=0x00000000
[1408] 14:22:50:847: [TRACE] DoFunc: result = x0
[1408] 14:22:50:847: [TRACE] DoFunc -- enter
[1408] 14:22:50:847: [TRACE] AllocClientResources: enter
[1408] 14:22:50:847: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:848: [TRACE] DoFunc: back from srv- return code=0x80000023
[1408] 14:22:50:848: [TRACE] DoFunc: result = x80000023
[1408] 14:22:50:849: [TRACE] DoFunc -- enter
[1408] 14:22:50:849: [TRACE] AllocClientResources: enter
[1408] 14:22:50:849: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:850: [TRACE] DoFunc: back from srv- return code=0x00000000
[1408] 14:22:50:850: [TRACE] DoFunc: result = x0
[1408] 14:22:50:850: [TRACE] DoFunc -- enter
[1408] 14:22:50:850: [TRACE] AllocClientResources: enter
[1408] 14:22:50:850: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:852: [TRACE] DoFunc: back from srv- return code=0x80000023
[1408] 14:22:50:852: [TRACE] DoFunc: result = x80000023
[1408] 14:22:50:942: [TRACE] DoFunc -- enter
[1408] 14:22:50:942: [TRACE] AllocClientResources: enter
[1408] 14:22:50:942: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:942: [TRACE] DoFunc: back from srv- return code=0x00000000
[1408] 14:22:50:942: [TRACE] DoFunc: result = x0
[1408] 14:22:50:943: [TRACE] DoFunc: back from srv- return code=0x00000000
[1408] 14:22:50:943: [TRACE] DoFunc: result = x0
[1408] 14:22:50:943: [TRACE] DoFunc -- enter
[1408] 14:22:50:943: [TRACE] AllocClientResources: enter
[1408] 14:22:50:943: [TRACE] AllocClientResources: exit, returning x0
[1408] 14:22:50:943: [TRACE] DoFunc: back from srv- return code=0x80000049
[1408] 14:22:50:943: [TRACE] DoFunc: result = x80000049
[5652] 14:23:55:971: [TRACE] DoFunc -- enter
[5652] 14:23:55:971: [TRACE] AllocClientResources: enter
[5652] 14:23:55:971: [TRACE] AllocClientResources: exit, returning x0
