VS2003 - File.Delete does not work in Vista?
Y
yxq
Hello,
In Visual Stadio 2003, the function File.Delete will not work in Windows
Vista 5365, why?
And the Win32 API SHFileOperation also not work in Vista, how to delete a
file in
Vista?
Thank you
Z
Zack Whittaker
Because your Visual Studio version is tooooo old!
Get an Express C# Edition - that's fully compatible.
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"yxq" <[email protected]> wrote in message
news:%[email protected]
> Hello,
> Vista 5365, why?
> file in
> Vista?
> Thank you
A
Andre Da Costa
Thats a stupid answer. If Visual Basic 6 can run on Windows Vista which
predates Visual Studio .NET 2003 by 1 version, (Visual Studio .NET 2002),
its obviously not a version issue. Zack, I am not attacking you, I am just
pointing out your lack of understanding and lack of effort to even "try" and
give a sensible answer sometimes.
yxq, I am not a programmer, so I can't answer your question, but I can make
a few "sensible" suggestions, (I have Visual Studio 2005 Professional
Edition and I am struggling to even figure out how to launch a new project).
The best you can do is try the same procedure in a later build of Vista
(5381) to see if the problem reoccurrs or is fixed or try beta 2 when it
becomes public. Also, you could file a report in the mean time, since this
is an interim build which means you are either a Technical Tester or TAP
customer.
You could also start a topic on this issue in the private newsgroups, maybe
someone was having a similar issue and found a workaround. Some have
suggested right clicking on the Visual Studio IDE executable and running it
with Elevated priviledges, maybe that will work.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Zack Whittaker" <[email protected]> wrote in message
news:[email protected]
> Zack Whittaker
> not
> that up!
>> Hello,
>> Vista 5365, why?
>> file in
>> Vista?
>> Thank you
G
Gabriel Lozano-Morán
The Delete() operation is a operation of the File class in the System.IO
namespace. Behind the scenes the Delete() operation will call the
DeleteFile() function in the Kernel32 library and nothing changed in the
..NET Framework v2.0. With other words this should work normally since
neither the DeleteFile() nor the SHFileOperation has been deprecated to my
knowledge.
What exception is being thrown exactly?
The .NET Aficionado
http://www.pointerx.net
> Hello,
> Vista 5365, why?
> file in
> Vista?
> Thank you
