Way to add 'select all' to the right click menu?
I
Imageman
Vista 64bit PC
Is there a way to add 'select all' to the right click menu for use in
Windows Explorer? Help appreciated - IM
USA - Washington State, Kitsap County "Replies welcomed as a sign of good
etiquette" Nostradamus 1560
V
Victor
Why not press Ctrl+A of the keyboard?
"Imageman" <Imageman@xxxxxx> wrote in message
news:e7ednT4QRItleCjanZ2dnUVZ_vumnZ2d@xxxxxx
> Vista 64bit PC
> good etiquette" Nostradamus 1560
Dzomlija
Resistance is Futile
Vista 64bit PC
Not exactly the solution you wanted, but it achieves the same effect, with less clicks:
  1. Open an Explorer Window by pressing <WINKEY>+<E>
  2. Click "Organize"
  3. Click "Folder and Search Options"
  4. Click the "View" tab to open it
  5. Find the "Use check boxes to select items" entry in the "Advanced Settings" list, and click the box to place a check in it
  6. Click "Apply"
  7. Click "OK"
In addition to adding the facility to use check boxes (they appear only when you move the mouse over an icon) to select files, the "Name" column header will also contain a check box. Clicking this check box will select all files - as shown in the following screenshot:
This way you don't have to right-click and click again to "Select All", as you wanted.
If you don't like the checkbox solution, you can also always use the hotkey combo of <CTRL>+<A>, but I find the checkbox is quicker, as I don't have to remove my hand from the mouse.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
M
Mick Murphy
Open windows Explorer>Organise >Layout>MenuBar.
If you did not have the MenuBar
Click on Edit> then Select All
"Imageman" wrote:
> Vista 64bit PC
I
Imageman
Victor - Thanks for the tip. I'd still like to get 'select all' in the right
click menu . . . IM
"Victor" <1@xxxxxx> wrote in message news:47b5ea12$1@xxxxxx-privat.org...
>> Vista 64bit PC
