WCF+Adobe Flash
Y
Yevgeniy
Hi, I'm new to WCF ,coming with asp.net background and would
appreciate help with WCF usage guidelines for fallowing :
My challenge is to design and build web based system on 2
technologies :
Clients are adobe Flash applications
And server side implemented with WCF
Main limitation is that I cant use .net based wcf clients, my consumer
is flash app that send-recieves soap messages, please share your
thoughts :
1) what is better option for wcf services hosting ? IIS+ASMX / windows
service ?
2) how WCF can help to implement clients session ? basically what I
need is that only authenticated clients can access wcf services.
(Asp.net way is to create authentication cookie and validate that
cookie automatically on each page load)
3) how can enforce each wcf request in client session to be processed
in order of arrival
thanks much for any help
V
Vadym Stetsiak
Hello, Yevgeniy!
Y> 1) what is better option for wcf services hosting ? IIS+ASMX /
Y> windows service ?
If you want additional logging and more flexible control over WCF Windows
service can be an option.
Y> 2) how WCF can help to implement clients session ? basically what I
Y> need is that only authenticated clients can access wcf services.
Y> (Asp.net way is to create authentication cookie and validate that
Y> cookie automatically on each page load)
WCF supports authentication
( http://msdn2.microsoft.com/en-us/library/ms733775.aspx )
Y> 3) how can enforce each wcf request in client session to be processed
Y> in order of arrival
WCF service will process SOAP requests from the client in order of arrival.
With best regards, Vadym Stetsiak.
Blog: http://vadmyst.blogspot.com
You wrote on Mon, 03 Sep 2007 13:11:44 -0700:
Y> Hi, I'm new to WCF ,coming with asp.net background and would
Y> appreciate help with WCF usage guidelines for fallowing :
Y> My challenge is to design and build web based system on 2
Y> technologies :
Y> Clients are adobe Flash applications
Y> And server side implemented with WCF
Y> Main limitation is that I cant use .net based wcf clients, my
Y> consumer is flash app that send-recieves soap messages, please share
Y> your thoughts :
Y> thanks much for any help
Y
Yevgeniy
hi Vadim, thanks for response.
maybe i need to be more specific with my questions :
1) from performance point of view and authentication/authorisation
support, witch hosting option is better for services exposed for web
clients
2) when service consumer is flash client, how authorisation could be
implemented ( for example implementing some Login function that will
create a token and pass it to client and client will send it with
every service call via SOAP headers)
On Sep 4, 11:21 am, "Vadym Stetsiak" <[email protected]> wrote:
> Hello, Yevgeniy!
> (http://msdn2.microsoft.com/en-us/library/ms733775.aspx)
> Blog:http://vadmyst.blogspot.com
> Y> technologies :
> Y> your thoughts :
V
Vadym Stetsiak
Hello, Yevgeniy!
1. IIS hosting model provides fail protection, activation etc.
However, if you need your service up and running before the first
request comes in - IIS won't suit you.
If only HTTP endpoints will be used performance can be litterally equal,
since both IIS and self-hosted service use http.sys.
2. Good description of WCF security is given here
http://go.microsoft.com/?linkid=5008388
You wrote on Tue, 04 Sep 2007 10:58:07 -0000:
Y> hi Vadim, thanks for response.
Y> maybe i need to be more specific with my questions :
Y> 1) from performance point of view and authentication/authorisation
Y> support, witch hosting option is better for services exposed for web
Y> clients
Y> 2) when service consumer is flash client, how authorisation could be
Y> implemented ( for example implementing some Login function that will
Y> create a token and pass it to client and client will send it with
Y> every service call via SOAP headers)
Y> On Sep 4, 11:21 am, "Vadym Stetsiak" <[email protected]> wrote:
Y>>> 1) what is better option for wcf services hosting ? IIS+ASMX /
Y>>> windows service ?
>> Windows service can be an option.
Y>>> 2) how WCF can help to implement clients session ? basically what I
Y>>> need is that only authenticated clients can access wcf services.
Y>>> (Asp.net way is to create authentication cookie and validate that
Y>>> cookie automatically on each page load)
Y>>> 3) how can enforce each wcf request in client session to be
Y>>> processed in order of arrival
>> arrival.
Y>>> Hi, I'm new to WCF ,coming with asp.net background and would
Y>>> appreciate help with WCF usage guidelines for fallowing :
Y>>> My challenge is to design and build web based system on 2
Y>>> technologies :
Y>>> Clients are adobe Flash applications
Y>>> And server side implemented with WCF
Y>>> Main limitation is that I cant use .net based wcf clients, my
Y>>> consumer is flash app that send-recieves soap messages, please
Y>>> share your thoughts :
Y>>> thanks much for any help
EricTile
Hi Yevgeniy,
You wrote:
"Main limitation is that I cant use .net based wcf clients, my consumer is flash app that send-recieves soap messages..."
I'm trying to use wcf with flash but get 'Unable to connect to endpoint error'.
Is wcf not compatible with flash?
Thanks,
EricTile
Y
Yevgeniy
On Mar 4, 12:02 am, EricTile <[email protected]> wrote:
> Hi Yevgeniy,
> error'.
> Thanks,
> EricTile
> EricTile
hi Eric,
we successfully used Flax clients with WCF (basicHTTPBinding)
can you access same service from native client ? generate C# client
with visual studio and see if it works
it seems like server side problem according to your error
