WD Caviar 80gb secondary IDE drive
SMOKKINU
On the starting line
Power User
Ok guys... I had a WD 80gb Caviar HDD in my old Dell, it has alot of important files on it that I am trying to get, so I pulled out the IDE cable that came with my P6T Deluxe, plugged it in to the MB, too the Hard drive, and plugged in the power cable.
I also swapped the jumper on the HDD to "Slave" it was on "CS" not sure what that means, but I assumed it made the drive the Master drive.
Anyway, PC boots up fine, but HDD is not detected on bootup, but I can see it in device manager in Vista, but the drive is not showing up in explorer for me to explore through....
Any help is appreciated guys!!!!!
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    6gb MUSHKIN DDR3 1866
    TWO x EVGA NVidia GTX 285
    Soundblaster Extreme
    ASUS 24inch 2ms LCD
    1920x1080
    4 x OCZ Vertex 60GB, 1 x Western Digital Velociraptor 300GB, 1TB Western Digital Caviar Black
    Corsair 1000W
    Coolermaster HAF 932
    Water cooled
    Microsoft Regular USB w/wheel
    Saitek Cyborg Deluxe
    Cable 15mbps
SMOKKINU
Power User
nevermind guys, I managed to fix it :) shows up in windows vista now :)
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
m9040n
FYI - CS means Cable Select. Thats the best way to set it!
    HP Pavilion Elite 9000 Series/m9040n
    Intel Core 2 Duo E6750 2.66 GHz 1333MHz FSB
    Asus IPIBL-LA (Berkeley-GL8E)
    8GB 800MHz DDR2 5-5-5-15 by G.Skill
    EVGA Nvidia 512MB DDR3 9800 GTX+ Superclocked Edition
    Realtek (built-in) ALC888S HD 7.1
    Samsung HLN567W 56" DLP
    (2) WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3Gb/s in RAID 0
    PC Power and Cooling PPCS500D 500W
    HP Media Center Edition
    Thermaltake
    Adesso WKB-3000UB 2.4GHz Wireless w/Optical Trackball
    FIOS 20MB down/5MB up
    Hauppauge WinTV HVR-1600 MCE ATSC/NTSC/FM (*QAM)
SMOKKINU
Power User
man this drive is insane slow compared to my Velociraptor 300gb hahahahha.... i didnt realize just how slow my old PC really was hahaha.
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
m9040n
One other issue you are up against in case you aren't aware. Vista is much much slower at copying or moving files around then XP, I mean really Slow!
    Thermaltake
SMOKKINU
Power User
i am having no issues whatsoever moving files on my WD 300gb Veloc???? just on the older drive, it is old as the dinosaurs.
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
