WD SES Device USB Device
A
Andyba
Just acquired a new WD Passport My Essential drive (WDBAAA2500ABK-00) for
SBS 2008 backups.
Turns out it's not exactly the same as previous ones I've bought. Slightly
smaller, and with a different style USB connection on the drive.
More importantly it shows an error in device manager, and a driver update
fails to find anything to correct the error.
I have done a backup (but not a restore) with it, with no indicated error,
but I should really find the correct driver to loose the exclamation mark.
Anyone else had this?
TIA
Andy
M
Merv Porter [SBS-MVP]
Is this one of those "SES" drives that has the Smartware on it?
Windows fails to locate drivers for an external hard drive
http://wdc.custhelp.com/cgi-bin/wdc...mNoX3RleHQ9c2VzIGRldmljZQ!!&p_li=&p_topview=1
"Andyba" <andy_baguley@newsgroup> wrote in message
news:#4aCkdflKHA.4772@newsgroup
> SBS 2008 backups.
> TIA
> Andy
A
Andyba
Yes, it "did" have Smartware on it.
I have looked at that page previously too, and originally assumed that OS
support in Windows 7 would include OS support in SBS2008, but not apparently
so.
My attempts to get rid of the driver error have involved:
Update to firmware. (EssentialEliteFirmwareUpdaterv1.032_1.0.7.4)
Update to Smartware. (WDSmartWare_SoftwareUpdater_for_Windows_1_2_0_7a)
Use of Virtual CD manager to remove the Virtual CD.
(WDSmartWareVirtualCDManagerforWindows-v1.0.7.4)
Then a full NTFS format.
Finally when configured as an SBS 2008 backup drive it will have received
another trashing!
It's presently formatted NTFS and not configured as an SBS backup drive.
I've just tried it now on OS's that have never seen it before, and have no
WD software installed.
XP SP3. Wanted to connect to the internet to find a driver. Same device
manager error as SBS2008. Presently I've not connected to try and find one.
Shows up as G: in Disk Management, but does not appear in "My Computer".
Vista and Windows 7. Same device manager error and cancelled driver search
as XP, except it did show in "Computer", and I was able to read and write.
I'd like to control the driver install so I know were it comes from, hence
the reason for not allowing Vista and Windows 7 to search the internet.
I thought SBS backup was going to be easy, and it was with the previous WD
Passport, but this new beast has me searching for a tape drive!
Rgds
"Merv Porter [SBS-MVP]" <mwport@newsgroup_spam_hotmail.com> wrote in message
news:%23K3n8chlKHA.5040@newsgroup
>> SBS 2008 backups.
>> Slightly smaller, and with a different style USB connection on the drive.
>> error, but I should really find the correct driver to loose the
>> exclamation mark.
>> TIA
>> Andy
M
I haven't found anything that will allow you to disable the SES (SCSI
Enclosure Services) on these new drives. So, if you can't install the
driver for it, you'll continually get the pop-up to install it. It appears
Western Digital has taken an otherwise good drive and turned it into a
brick. Sad to see this as I've been using their Passport drives for the
past 3 years without incident. At this point, I would return the drive for
a full refund and go to their competition for an external hard drive.
news:urgRMSplKHA.3792@newsgroup
> apparently so.
> another trashing!
> one. Shows up as G: in Disk Management, but does not appear in "My
> Computer".
> Rgds
>>> for SBS 2008 backups.
>>> drive.
>>> update fails to find anything to correct the error.
>>> exclamation mark.
>>> TIA
>>> Andy
A
Andyba
news:uHFAS4qlKHA.2164@newsgroup
There is some more info here, and a link to a driver, although I don't think
I'll try it on a server.
http://www.avforums.com/forums/networking-nas/1104424-new-wd-passport-smartware.html
>It appears Western Digital has taken an otherwise good drive and turned it
>into a brick. Sad to see this as I've been using their Passport drives for
>the past 3 years without incident.
Yup
http://www.amazon.com/Western-Digit...iewpoints=1&sortBy=bySubmissionDateDescending
The comments about the dodgey connector convinced me. Not what you want when
you are changing drives regularly!
>At this point, I would return the drive for a full refund and go to their
Any Reccomendations?
Rgds
Andy
>> apparently so.
>> another trashing!
>> no WD software installed.
>> Computer".
>> search as XP, except it did show in "Computer", and I was able to read
>> and write.
>> hence the reason for not allowing Vista and Windows 7 to search the
>> internet.
>> WD Passport, but this new beast has me searching for a tape drive!
>> Rgds
>>>> drive.
>>>> exclamation mark.
>>>> TIA
>>>> Andy
M
I haven't had the need to buy a new USB drive for a while, but I'd probably
give the Seagate Freeagent Go drives a try.
Seagate FreeAgent Go 500 GB USB 2.0 Portable External Hard
http://www.amazon.com/Seagate-FreeAgent-Portable-External-ST905003FGA2E1-RK/dp/B001FWCDQG
I've seen some data that suggests that the USB connectors on most consumer
and business grade equipment is really only intended for 50-500 connects or
disconnects. To reduce the wear and tear on the external drive connector
and on the server's USB connector, I usually buy a (Male A-to-Female A)
extender USB cable, connect it to the server, connect the USB cable that
comes with the external USB drive to that drive and then mate the two
cables. When it comes time to switch out external drives, I break the
connection between the extender cable and the external drive's USB cable,
always leaving the USB cable connected to the external drive and the
extender cable connected to the server. The second external drive, again
with it's short USB cable always connected to it, is then connected to the
extender cable. This seems to work well.
news:#ff8F6slKHA.2188@newsgroup
> think I'll try it on a server.
>>for the past 3 years without incident.
> Yup
> when you are changing drives regularly!
> Rgds
> Andy
>>> OS support in Windows 7 would include OS support in SBS2008, but not
>>> apparently so.
>>> received another trashing!
>>> Computer".
>>> and write.
>>> internet.
>>> Rgds
>>>>> drive.
>>>>> exclamation mark.
>>>>> TIA
>>>>> Andy
L
Les Connor [SBS MVP]
I've had good results with the seagates, including the 1TB drives.
For swapping, HP has some nice 2.5" drives (320gb), that slip into a cradle
like a cell phone charging cradle - might save the connectors some stress.
They also come with a zip-up carrying case.
news:OdGt1atlKHA.5608@newsgroup
> probably give the Seagate Freeagent Go drives a try.
> or disconnects. To reduce the wear and tear on the external drive
> connector and on the server's USB connector, I usually buy a (Male
> A-to-Female A) extender USB cable, connect it to the server, connect the
> USB cable that comes with the external USB drive to that drive and then
> mate the two cables. When it comes time to switch out external drives, I
> break the connection between the extender cable and the external drive's
> USB cable, always leaving the USB cable connected to the external drive
> and the extender cable connected to the server. The second external
> drive, again with it's short USB cable always connected to it, is then
> connected to the extender cable. This seems to work well.
>>>it into a brick. Sad to see this as I've been using their Passport
>>>drives for the past 3 years without incident.
>> Yup
>> Rgds
>> Andy
>>>> apparently so.
>>>> drive.
>>>> Computer".
>>>> and write.
>>>> internet.
>>>> Rgds
>>>>>> drive.
>>>>>> exclamation mark.
>>>>>> TIA
>>>>>> Andy
M
#8
Do the 1TB FreeAgent Go units require an external power supply or do they
pull their power from the USB port (as with the lesser capacity drives)?
"Les Connor [SBS MVP]" <les.connor@newsgroup> wrote in message
news:OdheUz4lKHA.2184@newsgroup
> cradle like a cell phone charging cradle - might save the connectors some
> stress. They also come with a zip-up carrying case.
>> consumer and business grade equipment is really only intended for 50-500
>> connects or disconnects. To reduce the wear and tear on the external
>> drive connector and on the server's USB connector, I usually buy a (Male
>>> Yup
>>> Rgds
>>> Andy
>>>>> apparently so.
>>>>> drive.
>>>>> have no WD software installed.
>>>>> device manager error as SBS2008. Presently I've not connected to try
>>>>> and find one. Shows up as G: in Disk Management, but does not appear
>>>>> in "My Computer".
>>>>> and write.
>>>>> internet.
>>>>> previous WD Passport, but this new beast has me searching for a tape
>>>>> drive!
>>>>> Rgds
>>>>>>> (WDBAAA2500ABK-00) for SBS 2008 backups.
>>>>>>> drive.
>>>>>>> exclamation mark.
>>>>>>> TIA
>>>>>>> Andy
L
#9
I'm not sure if mine is a "go" or not, but it uses external power.
news:eJKxbY6lKHA.2184@newsgroup
>>> I break the connection between the extender cable and the external
>>> drive's USB cable, always leaving the USB cable connected to the
>>> external drive and the extender cable connected to the server. The
>>> second external drive, again with it's short USB cable always connected
>>> to it, is then connected to the extender cable. This seems to work
>>> well.
>>>> Yup
>>>> Rgds
>>>> Andy
>>>>>> that OS support in Windows 7 would include OS support in SBS2008, but
>>>>>> not apparently so.
>>>>>> drive.
>>>>>> in "My Computer".
>>>>>> read and write.
>>>>>> internet.
>>>>>> drive!
>>>>>> Rgds
>>>>>>>> drive.
>>>>>>>> exclamation mark.
>>>>>>>> TIA
>>>>>>>> Andy
M
#10
I've been trying to avoid drives with external power supplies. They're fine
as long as all external backup drives are identical. But when a drive goes
out after year two or three and you have to buy a new drive with a different
power supply, the client can get confused when swapping out both drive *and*
power supply. Using the wrong power supply can lead to some headaches.
news:uQOiwhEmKHA.3840@newsgroup
>>> some stress. They also come with a zip-up carrying case.
>>>> 50-500 connects or disconnects. To reduce the wear and tear on the
>>>> external drive connector and on the server's USB connector, I usually
>>>> buy a (Male A-to-Female A) extender USB cable, connect it to the
>>>> server, connect the USB cable that comes with the external USB drive to
>>>> that drive and then mate the two cables. When it comes time to switch
>>>> out external drives, I break the connection between the extender cable
>>>> and the external drive's USB cable, always leaving the USB cable
>>>> connected to the external drive and the extender cable connected to the
>>>> server. The second external drive, again with it's short USB cable
>>>> always connected to it, is then connected to the extender cable. This
>>>> seems to work well.
>>>>>>turned it into a brick. Sad to see this as I've been using their
>>>>>>Passport drives for the past 3 years without incident.
>>>>> Yup
>>>>> want when you are changing drives regularly!
>>>>> Rgds
>>>>> Andy
>>>>>>> but not apparently so.
>>>>>>> drive.
>>>>>>> in "My Computer".
>>>>>>> read and write.
>>>>>>> internet.
>>>>>>> drive!
>>>>>>> Rgds
>>>>>>> message news:%23K3n8chlKHA.5040@newsgroup
>>>>>>>>> drive.
>>>>>>>>> indicated error, but I should really find the correct driver to
>>>>>>>>> TIA
>>>>>>>>> Andy
M
#11
It appears that Seagate also makes a "dock" for the Freeagent Go drives:
(the "dock" is the one on the left; best picture I could find)
http://www.geek.com/wp-content/uploads/2009/04/packagecontents.jpg
This may be the way to go if you want to use the Freeagent laptop drives.
news:OinPirEmKHA.1536@newsgroup
> fine as long as all external backup drives are identical. But when a
> drive goes out after year two or three and you have to buy a new drive
> with a different power supply, the client can get confused when swapping
> out both drive *and* power supply. Using the wrong power supply can lead
> to some headaches.
>>> they pull their power from the USB port (as with the lesser capacity
>>> drives)?
>>>>> to that drive and then mate the two cables. When it comes time to
>>>>> switch out external drives, I break the connection between the
>>>>> extender cable and the external drive's USB cable, always leaving the
>>>>> USB cable connected to the external drive and the extender cable
>>>>> connected to the server. The second external drive, again with it's
>>>>>>>the driver for it, you'll continually get the pop-up to install it.
>>>>>> don't think I'll try it on a server.
>>>>>> Yup
>>>>>> Rgds
>>>>>> Andy
>>>>>>>> drive.
>>>>>>>> try and find one. Shows up as G: in Disk Management, but does not
>>>>>>>> read and write.
>>>>>>>> from, hence the reason for not allowing Vista and Windows 7 to
>>>>>>>> tape drive!
>>>>>>>> Rgds
>>>>>>>>>> the drive.
>>>>>>>>>> driver update fails to find anything to correct the error.
>>>>>>>>>> TIA
>>>>>>>>>> Andy
A
Andyba
#12
I've just received a Seagate Expansions 250GB
http://www.ebuyer.com/product/160906
Similar to the Freeagent, but a bit cheaper, with 2yr warranty as opposed to
five, if it doesn't get lost before then!
Standard mini-usb too. Doesn't look like it will fit that cradle as the
socket is on a long edge.
More importantly it connected, and configured straight off, with no problem.
Done a test backup fine, so off to the clients it goes tomorrow.
Rgds
news:OUuVYUGmKHA.3840@newsgroup
>> to some headaches.
>>>> drives)?
>>>>>>> message news:uHFAS4qlKHA.2164@newsgroup
>>>>>>>>(SCSI Enclosure Services) on these new drives. So, if you can't
>>>>>>>>install the driver for it, you'll continually get the pop-up to
>>>>>>>>install it.
>>>>>>> Yup
>>>>>>> Rgds
>>>>>>> Andy
>>>>>>>>> drive.
>>>>>>>>> driver search as XP, except it did show in "Computer", and I was
>>>>>>>>> tape drive!
>>>>>>>>> Rgds
>>>>>>>>>>> bought. Slightly smaller, and with a different style USB
>>>>>>>>>>> TIA
>>>>>>>>>>> Andy
