Solved Web links opening in Word
Fast-Eddie
When I click on a web link in an application, it opens the url in MS Word, not Firefox (default bowser).
For example:
In CCleaner if I click the 'check for updates' link in the bottom of the window, Word will open up, a download box will appear and then it displays the website as a document.
This happens for all apps, however it doesn't happen if I click on a .html/.url document from explorer, that will launch Firefox just fine.
Any help geting this back to normal would be appreciated.
Vista x64
Word 2007
    Vadim (& Me) [orig build: Nov 2007]
    Intel Core 2 Quad Q6700 @3GHz
    Asus P5N32-E SLI Plus
    4GB – OCZ DDR2-1150 FlexXLC (4x1024MB)
    ASUS Nvidia GTX 470 1280Mb
    ASUS Xonar DX (PCIe) - 24-bit 192 kHz
    ASUS PA246Q 24.1-inch ProArt P-IPS LCD
    1920x1200
    150Gb Raptor 10000rpm (OS)
    500Gb Barracuda 7200rpm (Storage)
    OCZ 700W ModXStream Pro
    Thermaltake 'Shark' - Black Aluminium
    Scythe Infinity Heatpipe CPU Cooler &4 Fans(digital control)
    Trust wireless 305ks (had it since 2003! still going strong)
    Razer Lachesis + Kensington Trackball + Wacom Intuos3
    [very lame]
    Icy Box 16-in-1 internal USB Card reader
Change the Associations.
I will be back with the tutorial.
Yeah that's done it, thanks very much.
I checked all the file associations, but for got to check the default program bit, doh!
    1920x1200
    [very lame]
You made me happy, too. Feels great to find a quick fix to a problem. Have a great day.
RIGHT ON Rich
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
