What CD/DVD burning software works with Vista?
C
Chris
Are there any suitable freeware ones?
And ... does Vista have burning software built-in?
Chris
U
Ulf G
I use this http://www.imgburn.com/ software.
Its very nice imho.
/Ulf
"Chris" <nospam@[127.0.0.1]> wrote in message
news:X2gyD4AQokKFFw+U@[127.0.0.1]...
> Chris
P
Peter
Vista has its own CD/DVD burning software but it may not offer as many
options as external programs.
Peter
Toronto, Canada
XP Pro SP2 x 2 + Vista RC2 5744
P4 HT @ 3.0ghz, 700gb HDD, 2.0gb DDR
Creative SB Audigy 4 Sound, ATI Radeon 9550 Graphics
TS H429A + H552U CD/DVD Combi-Drives
Sony DRU820A x 2 DVD-RAM Combi-Drives
> Chris
C
chriske911
Chris formulated on maandag :
I use silent night micro, seems to work with every windows OS and every
build of vista so far
grtz
W
Vista does have a limited burning function built into wmp11, moviemaker and
windows explorer but if you want more advanced options your probably better
off installing burning software of your own.
I have Ulead burn now ver1.15 it came bundled with my burner it works very
well with vista RC2
> Chris
F
F.C.telefonica
I use DeepBurner free XP edition, so I did from RC1 -5600 to burn iso file
for RC2-5744, and could install it.
ciao
> Chris
L
Lang Murphy
I too have used DeepBurner. There's a freeware version available at
www.deepburner.com.
Lang
> Chris
A
AVALANCHE@SNOWBOUND.COM
#8
On Tue, 10 Oct 2006 00:02:52 -0400, "Lang Murphy"
>www.deepburner.com.
>Lang
>> Chris
gear video 8.02 works just fine
R
Rasmus Bertelsen
#9
"Lang Murphy" <lang_murphy@hotmail.com> wrote in message
news:32AED7F2-ECC2-455C-9BEB-8B938BD001B2@microsoft.com...
>www.deepburner.com.
> Lang
Is that the portable version? Because when i try to install the "normal"
freeware version, i get a message saying: "Cannot install the file
"D:\Program files\
Astonsoft\DeepBurner\Autorun\cdrun.exe"!" And then the install program just
stops. I'm using Windows Vista RC1 Build 5600.
Regards,
Rasmus Bertelsen
R
Rob W
#10
Curious, have you tried installing it in compatibility mode (right click the
launch icon, somewhere in the properties is compatibility, I usually set :
(1) Run as Administrator, and (2) Run in Windows XP SP2 mode. Everything
likes to work after that.
-Rob
"Rasmus Bertelsen" <rasbert@nowhere.dk> wrote in message
news:uvbi9tP$GHA.3352@TK2MSFTNGP03.phx.gbl...
>>www.deepburner.com.
>> Lang
> "D:\Program files\
> just
> Regards,
> Rasmus Bertelsen
