Solved What too upgarde my video card too?
11
Hi
I'm new round here but I've seen you are all very helpful, so i hope you can help.
My Video card has gone up in smoke, it's very hard to even post this thread, everything look's like an Andy Worhole picture, so I'm assuming it broke and the computer is using some standard mother board graphic's.
I Obviously need too upgrade but i don't know how far i can go. I was running an Nvidea 8300 GS, as far as i can tell it's a PCI e with a memory of 256 Mb. obvousily i don't want one worse then this. I have heard my power supple might need upgrading for top line graphic's cards. I also think that my Intel core due 2 might stop me from getting the most out of a top line card. The last thing too mention is while i'm not a gamer, it would be nice too play GTA3 or Duke nukem forever, I'm more of an internet browser and have children.
Hope you can help
    Packard Bell
    Intel Core 2 duo CPU
    2.00 Gb
    High Definaition Audio Device
    Dell flat screen
MrNeeds
PC Geek
1,823
Location
Lymm, Cheshire, UK
this might be just what you're looking for, it's a low end card but should be able to run off your Power supply, it uses hardly any power and has enough kick to play the games you want to play :)
GeForce GT 520 - Overview - GeForce
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Patonb
2,245
Welcome to the forum... My question is what size case do you have?
I'd go for a gt 440. Its low power draw, same as a 520, and nice performance ~ 8800/9800 gt.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
11
Don't want too sound too new but are both them cards not lower then the one I'm using at the mo?
My case is 40 deep X 40 high X 20 Wide CM, approx, just out of interest how is this relevant are they not all the same with some tower and some desktop?
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
The gt 440 is relatively like a 8800/9800 gt, which is 6 cards better roughly.
The case size matter as some cases are "slim" cases, and require low profile cards, which are only certain models.
The 440 is only in a "full" size card.
The 520 is 1 to 2 cards lower than the 440, and on par with the 420.
11
Is the sparkle and palit Geforece GT 440 the same as the Nvidia?
I keep loosing out on E-bay.
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
Yes, Nvidia does not actually make cards. They make card designs, which they selll to evga, pallit, sparkle etc, who then make the card you actually buy.
11
#8
Everyone's been great, great advice.
I seem too be aiming for a geoforce gt 440.
I'm just stuck on one last problem, can anyone recommend a cheap website were i can buy one, second hand will do, not having much look with e-bay?
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#9
Where do you live?
The US?
11
#10
unfortunately not, good old Great Britain. So internet suggestion would prob be best!
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#11
Okay, thats not bad at all. However, the cheapest I can find is at overclockers.co.uk at 54 pounds after VAT
11
#13
I've managed to get my hands on a geforce 9600 GT, will this be compatible? Too much of a power draw? i've seen that it has a higher bench mark then the 440.
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#14
Hmm, that depends. There is 2 versions, one is 300W and 1s 400W. That said, I just realized the 8300 isn't a dedicated card.
You power supply might not be big enough for any card. You need to find out what size the psu is. I'm no longer going to help if you don't.
Nothing against you, but thats a very important need info.
11
#15
As far as i can tell i have a fsp250-60hen power supply, it say's on the side 'total output continuous shall not exceed 250 watts' Is this the info you need?
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#16
Yha... Unfortunately when i found out the 8300 is on board, thats what I though.
You may get a 520/420/430 to run on it, though nvidia does claim 300W. Sorry to run you this far, then switch on you.
The minimum required psu, as stated by the companies, is 300W.
This is where you may get by on the current psu, and the new gpu, but it is not a garrentee.
You ned to decide how you want to go about it.. new gpu and risk it... or spend the cash and get both.
11
#17
I'm a bit confused, what would happen if i use the 9600 on the current supply? What are the draw back's?
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#18
It might not boot. You could experience bsod, but nothing that is really damaging.
If you have the 9600 for sure try it out. I just wouldnt want you to buy it and then find out it didn't work.
11
#19
Sorry bsod, don't know that one?
    Packard Bell
    2.00 Gb
    Dell flat screen
Patonb
2,245
#20
bsod is they nasty n dreadsed blues screen of death..... I.E it crashes
