Whats the first thing you do when you format?
AlexRD
Well, whats the first thing you do when you format your computer? :huh:
I usually run the Driver CD from Asus, then i install Auslogics Boostspeed and Vista Manager, enter the Performance Thread and choose some Tweaks for my Computer.
I uninstall all the BLOATWARE, disable some unused services from Vista and a priority:
-Disable the Sidebar...
Update all the drivers i need, Defragment my computer because windows comes with many fragmented files, clean my registry with registry cleaner, run a scan disk, run disk cleanup, adjust the power options so that when i close my Pc, my PC doesn`t sleep.
Adjust some settings at the Vista Manager, do Readyboost, disable UAC, Enable all files to be ready for archiving and disable the Index Searching.
Install some applications, configure my applications, and after all applications are ready and well configured, i install all my games. And after that, i run a Scan Disk, Defragment Filles, Clean my registry and do a disk cleanup.
After that, i`m ready to go.. LOL :confused:
Thanks,
Alex. :huh:
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    Asus G2s Keyboard from Logitech
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    2 MB Wireless Network
Install OS; install service pack; patch OS; install motherboard drivers; install graphics drivers; install sound drivers; defrag... always in that order.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Install OS; Service Packs; change page file [constant size]; Firewall/AV [unless I can stay disconnected and get these things from a disk]; Windows Updates; mobo drivers; vid drivers; other drivers; defrag; setting/services; programs; defrag.
    HP tx2000z
    AMD Turion 64 X2 TL-68 Gold Edition
    Quanta 305E/nVidia nForce 430
    4096MB DDR2 PC2-5300 @ 5-5-5-15
    nVidia GeForce Go 6150 64MB
    Realtek HD Audio/Altec Lansing
    250GB 5400RPM SATA
    8 Cell Lithium Ion Battery
    HP Echo tx2000z
I Also install the OS too :confused:
    Asus G2s
    17" Generic PnP
    1440x1280
Nah you don't need to install the OS, waste of time doing that.
I have a folder on my second hard drive which has all the setup files for stuff like firewall, AV, drivers etc, which I all install first. Then let Vista update, before putting my programs back on. When I have all the necessary stuff then I'll defrag and begin using the PC normally.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
...I have a folder on my second hard drive which has all the setup files for stuff like firewall, AV, drivers etc, which I all install first. Then let Vista update, before putting my programs back on. When I have all the necessary stuff then I'll defrag and begin using the PC normally.
I used to do that, and couldn't figure out why my XP install kept crashing.. Three formats later I figured out I had a virus on that second HD, and it hitched a ride every time :eek:
    HP tx2000z
    250GB 5400RPM SATA
    HP Echo tx2000z
Setup my screens and email, everything else I setup as I need :o
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Service Pack -> Programs -> Games -> Defrag.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Logitech G15 V1
    Razer Copperhead Tempest Blue
    100.0 Mbps
    Asus G2s
    17" Generic PnP
    1440x1280
Wipe the drive. Run microscope and test all hardware. Load OS, tear the house apart hunting for mb, driver's disk, and saved files (favorites, contacts, quicken.) Load boost speed and trend micro. Run updates. Run trend micro and Anolgistic boost speed. Go out side and lay in the hammock with a beer and a cigarette, weather permitting.
Wipe the drive. Run microscope and test all hardware. Load OS, tear the house apart hunting for mb, driver's disk, and saved files (favorites, contacts, quicken.) Load boost speed and trend micro. Run updates. Run trend micro and """"""""Anolgistic"""""""" boost speed. Go out side and lay in the hammock with a beer and a cigarette, weather permitting.
You mean Auslogics don`t you?
    Asus G2s
    17" Generic PnP
    1440x1280
12 pack = BEER!
    ASUS P5B-E Plus
    ASUS EN8800GT 512
    1440x900 @ 75Hz
    Logitech G15 V1
    100.0 Mbps
Okay you caught me. I am old and can't spell and spell check won't work if you use the wrong word.
Haha, found you on the NET Dude, you have to be careful when uploading your photos on those photobuckets things xD.
    Asus G2s
    17" Generic PnP
    1440x1280
He is almost as good looking as me. I didn't get the nickname of Yuck at work because I was a movie star. However if you notice you see a lot of fine looking ladies with ugly men. The contast makes they look even better.
+1. Absolutely positively in that order. Learned that the hard way with older ATI drivers for my x1650Pro512AGP card when I was testing and then first running Vista on the old machine - if I installed drivers for my older hardware before installing SP1, SP1 would not install.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Usually grab a 12 pack....
Forgot to add that myself, I usually prepare with food and drink as I know I'm in for a long night when I format my PC.
    ASUS Xonar DX
    100Mbps
what is a 12 pack?
Surely you jest....
No, and stop calling me Shirley.
I don't bother - I can walk to the kitchen and make a snack or wahtever, or pop on the boot tube for some R&R, but I usually extend a rebuild over a couple of days - I install essentials first, run for a day, then start with apps (essential) and then finally sometime around the weekend I am working on the 'little' things like WinMerge, etc.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
