when deleting xp in dual boot with vista first.
W
waher
so, having recieved no further reply to my previous post, i take it that no
one knows anyone who has sucessfully achieved this without reinstalling
vista? thanks to miscrosoft for no real help, even telling me it's
impossible. jude
i heard his refrain when the signal changed he was playing real good, for
free. Joni M.
http://www.geocities.com/waher/
Have you been checking for repies to your original post? Follofwing his a
reply I made originally;
"Actually it is easier to set up a XP/Vista dual boot than to remove XP
afterwards. Assuming (I know - lousy word!) XP on C and Vista on D - Vista
installs files - in particuler a hidden folder titled "Boot", which
contains DCDStore data, on C, which if deleted as in deleting the XP Windows
folder will prevent Vista from booting. Also in a dual boot setup, or
"remainder" of such, Vista looks for boot.ini.
Options: 1. Delete all folders/files in C except for folder Boot, and as a
safety measure Boot.ini, Boot.bak and Bootsect.bak. Shrink C and add
unallocated space to D.
2. Use BCDEdit (As a command line tool) or a third party program such as
VistaPro to modify Vista to boot directly from D.
3. Reformat and reinstall Vista
Above all - BACKUP!!!!!"
"waher" <waher@optonline.net> wrote in message
news:e1modzMuHHA.4572@TK2MSFTNGP02.phx.gbl...
> no one knows anyone who has sucessfully achieved this without reinstalling
> impossible. jude
> free. Joni M.
R
> impossible. jude
You did receive replies. Btw, this is a user group, not formal MS tech
support.
Rock [MS-MVP User/Shell]
V
Victek
> impossible. jude
> free. Joni M.
I am currently dual-booting XP and Vista. What I've read is you can delete
XP, move/resize the Vista partition to reclaim the space and then boot with
the Vista DVD and do a repair/install. Sounds good, doesn't it? I haven't
tried it though and cannot verify that it works. Perhaps someone here has
tried this and can comment?
W
waher
i finially had to reinstall due to failure of system restore. have a clean
install on a single boot. took 5 hours to reinstall all programs. went
without problems. hoping it holds. so, i havn't tried solution either.
have xp on seperate hard disc, unconnected, just in case.
thanks to
all, jude
"Victek" <Victek@xyz.com> wrote in message
news:%23TsbRlZuHHA.5028@TK2MSFTNGP02.phx.gbl...
>> reinstalling vista? thanks to miscrosoft for no real help, even telling
>> me it's impossible. jude
>> free. Joni M.
> delete XP, move/resize the Vista partition to reclaim the space and then
> boot with the Vista DVD and do a repair/install. Sounds good, doesn't it?
> I haven't tried it though and cannot verify that it works. Perhaps
> someone here has tried this and can comment?
E
Elden Fenison
On Thu, 28 Jun 2007 15:17:24 -0400, "waher" <waher@optonline.net>
Curious... why would it not "hold"?
-=Elden=-
http://www.moondog.org
