where are attachments saved to?
B
Bruiser72
I was just working on an excel received as an attachment and I clicked "save"
in excel and closed the file. I was expecting the attachment to be updated as
per Outlook, but it wasn't.
Any idea what mail did when I clicked "save"? I've tried searching the
machine for the file but no luck...
whs
2,026
Location
Germany/Florida
From Excel, it is saved in C:\Windows\System32. But it will not be easy to find it there because this is a giant folder. Hopefully you have the name. Else, do a search for .xls or .xlsx in the system32 folder.
In the future, use "Save as" - then you can define the storage folder yourself.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
G
Gary VanderMolen
NEVER edit an important attachment while opened via the mail client.
Attachments are opened/saved in your Temporary Internet Files folder
under a very cryptic name. It would be like looking for a needle in a
haystack, although the date/time stamp might provide a clue.
Gary VanderMolen, MS-MVP (Mail)
http://mvp.support.microsoft.com/profile/VanderMolen
"Bruiser72" <Bruiser72@xxxxxx> wrote in message news:C7511FF1-1945-45DA-9AAD-621879A4897A@xxxxxx
D
You should always always always always save the attachment to disk, close
the email, go to the saved file, then open it, if you want to edit it.
The file is probably located in a folder somewhere in
C:\Users\(youraccount)\AppData\Local\Microsoft\Windows\Temporary Internet
Files\Content.IE5
\AppData is normally hidden
\Temporary Internet Files is normally a hidden protected Operating System
file
You'll have to remove the checkmark (if they're hidden) in Windows Explorer:
Organize - Folder & Search Options - View
Windows 7 RC
http://get.live.com/wlmail/overview
http://download.live.com/wlmail
> "save"
> as
whs
2,026
Location
Germany/Florida
The way I understood the OP, he saved the file from within Excel. Do you think they are then still saved in a temporary internet file? I am not certain.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
R
Ron Sommer
"whs" <guest@xxxxxx-email.com> wrote in message
news:77f09cba61e215e1429d83ae2fe66a24@xxxxxx-gateway.com...
>> news:C7511FF1-1945-45DA-9AAD-621879A4897A@xxxxxx> > >
>> > "save"
>> > updated as
>> > the
>> > > machine for the file but no luck... > >
> not certain.
> whs
Excel is the default program for opening excel files. Temporary Internet
Files is the default attachment storage folder. Excel will save back to the
open location unless you do a Save As. It is still best to save the file
before editing, so any auto saves will be to the desired location.
Ron Sommer
MVP-Mail
M
Michael Santovec
The updated document was saved to the IE Temporary Internet Files (TIF).
That's where WLM saves a temporary copy of attachments when you open
them from within WLM.
You cannot update an attachment within a WLM message. You need to save
the attachment and then open it, or if you open it from within WLM, you
need to use the File, Save As option in the application to save the
updates to some place other than the TIF.
There is chance that the updated attachment is still in the TIF.
Any attachments, if they are still there, will Not show if you look at
the TIF from IE or the Windows Explorer normally. On Win XP You will be
able to see them if you use Start, Run and enter the command:
%userprofile%\Local Settings\Temporary Internet Files\Content.IE5\
or
C:\Documents and Settings\XXXX\Local Settings\Temporary Internet
Files\Content.IE5\
where XXXX is the Windows user. This assumes that you have not moved
the TIF. You can check the actual location by looking in IE at Tools,
Internet Options, General, Temporary Internet Files, Settings. The
\Content.IE5\ at the end is import or else you won't be able to see all
the files. You should see 4 folders with names such as A1B2C3D4.
You'll need to look in each folder for the missing files. The Search
function won't work.
An alternate access method is to open a Command Prompt window and use
"DOS" commands to locate and copy the file elsewhere. If you start at
the folder above the TIF and use the command
DIR /A /S *.XLS
(or whatever the file extension is) it will indicate if the file is
still there. You'll need to use a COPY command to copy the file
elsewhere. This will be cumbersome because of the peculiar folder
names.
Mike - http://TechHelp.Santovec.us
> "save"
> updated as
> the
whs
2,026
Location
Germany/Florida
#8
> not certain.
> whs
Ron Sommer
MVP-Mail
Thanks for clarifying that. I learned something - also from the explanation that Michael posted.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
