Where did my recycle bin go???
L
leogirl0813
I was downloading something, and when I closed everything, my recycle bin was
gone, but everything else was still there. Is there a way that I can get it
back? Or get another one for my desktop?? Please help.
M
Mick Murphy
Right-click the empty Desktop>Personalise>Change Desktop Icons> tick recycle
bin> apply >OK
If it is still ticked when you get there>untick it>apply>OK
Then go back there retick it>apply>OK. .
Mick Murphy - Qld - Australia
R
Ramesh, MS-MVP
Right-click on the Desktop, click Personalize, and in the left pane, click Change desktop icons. In the Desktop Icon Settings dialog, enable the Recycle Bin checkbox. Click OK. See also:
How to restore the Recycle bin icon that has been accidentally deleted:
http://www.winhelponline.com/articl...-icon-that-has-been-accidentally-deleted.html
How to hide the "Delete" command from Recycle Bin context menu in Windows Vista:
http://www.winhelponline.com/articl...ecycle-Bin-context-menu-in-Windows-Vista.html
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
Winhelponline.com blog http://www.winhelponline.com/blog
"leogirl0813" <leogirl0813@xxxxxx> wrote in message news:4C12ED97-40F9-47D9-BAA8-F58589C117B8@xxxxxx
Well Heaven alone knows if I'll do this correctly, what with having to follow proper etiquette and all :confused:!!
I just wanted to say *Thank You SO Much* to those who responded with such simplicity. Honestly I am just a tad embarrassed now that I 'know' that I didn't find my recycle bin, but I am ever SO grateful, regardless.
One more time, hopefully no one is put out by my attempt at thanks, but I'm so grateful I had to be sure it was said.
