where is .....\appdata\roaming ?
Hello
An old XP program I installed has put some files into a folder called
C:\users\myname\appdata\roaming .
I can find the folder using Vista 'search' facility, but not using explorer
The program works OK and I have got a shortcut to the folder I need, but why
does it not show up in explorer ?
Thanks
K
N
Nonny
On Sat, 10 May 2008 12:57:08 +0100, "KRK"
enable the viewing of hidden files
Re: where is .....\appdata\roaming ? -- sorry did not work
Hello, no, sorry, no change, thanks anyway
K
"Nonny" <nonnymoose@xxxxxx> wrote in message
news:0q4b24l54eq0u4ve3cc5qka4f5ib66u7l0@xxxxxx
>>explorer
J
John Barnett MVP
Disable 'show hidden files and folders' then go to
C:>Users>myname>AppData>Roaming. It's here when I click on my
C:\users\myname\appdata\roaming.
John Barnett MVP
Associate Expert
Windows Desktop Experience
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"KRK" <trebor@xxxxxx> wrote in message
news:eErJ8TpsIHA.5268@xxxxxx
> Hello
> explorer ??
> why does it not show up in explorer ?
> Thanks
> K
Re: where is .....\appdata\roaming ? --- Sorry, My mistake
Sorry all, was my mistake, I think it was finger trouble, have found the
files ok now
Thanks again
K
"John Barnett MVP" <freelance@xxxxxx> wrote in message
news:CCBF88EA-092F-4491-9D6A-7F1ABC94101B@xxxxxx
> John Barnett MVP
> Associate Expert
> for
> the
> mail/post..
>> Hello
>> explorer ??
>> Thanks
>> K
anield09
1
appdata roaming problem
i have a problem with my windows vista..every time i open my laptop there's an error appearing and it contains this "c:\users\compaq\appdata\roaming\odlfsof.dll" i don't know where i got this, it just appeared...and i think because of that error my yahoo messenger don't work.. what should i do? :(
